Question about HP q6659a - Designjet Z3100 44-in Photo Printer
The printer does not have a hard drive. Will it work when I plug a new hard drive into the formatter and turn the printer on? Can the driver or firmware be loaded on a blank hard drive?
  • Robert A. Watson
    Robert A. Watson Apr 11, 2015
    some printers will work without installing the software in a PC or Mac Operating System with basic functions only. If the computer doesn't have an operating system, the printer will not work except as a FAX machine for an All In One unit.
  • 773 Answers
The answer is.... NO. The hard drive must have an Operating System on it to recognize the printer's firmware first to identify it and then software to make it work for you.
Posted on Apr 11, 2015
  • Van Beard
    Van Beard Apr 11, 2015
    No I meant if I bought one with the firmware on it. Would it work
Installing a new blank hard drive in a DesignJet
The hard drive is the formatter in the T610.
HP has a special operating system software loaded on the hard drive, so you can't just format a blank one and install it.
The whole formatter assembly will need to be replaced.
Mar 15, 2014 | HP Designjet T610 InkJet Printer
Installing a new blank hard drive in a DesignJet T1100,T610
The T610 hard drive is the formatter and has a special operating system software installed on if from HP. You can't format a hard drive and install it...so the whole formatter assembly needs to be replaced when the hard drive goes bad...
How to download software on Hard z6100 Plotter
The software can not be downloaded from HP and installed on a new blank hard drive. HP has proprietary software on the hard drive that only comes with purchasing the entire formatter assembly.
Feb 26, 2014 | HP Designjet T610 InkJet Printer
Cp1525nw appears offline
If the system is unable to detect the printer, it will put the printer in offline mode. In this condition you won't get any print outs..
1. chk usb cable
2. un plug the usb cable, un install the drivers, plug the usb cable & chk new hard ware found?.. if not there is usb port issue, chk system usb port/s are working or not.. if yes
3. Replace printer formatter assmbly...
This printer network unable printer, why cant use through network? instead of replacing the formatter assembly...
Jan 02, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
Error 30.01.34
From the service manual.
30.1.34 Loss of communication with the formatter or cable error.
1. Turn off the device and then turn on the device.
2. Check the connections between the scanner assembly and the formatter.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. This error condition can be related to network traffic at the customer site; isolate the MFP from the network and troubleshoot accordingly.
5. If the message persists, replace the scanner assembly.
Nov 29, 2013 | HP LaserJet M3035 MFP Printer
My printer has went to offline mode
Model not mentioned:try it: Check usb cable, un plug & re plug both ends, check for online, if not, remove usb cable, un install the drivers, install once again connect Printer when dialog box appears, see new hard ware found or not if found do rest of loading if its not detecting, treat it major issue with USB port or formatter...
Feb 04, 2012 | HP Office Equipment & Supplies
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
HP LaserJet M5035 MFP
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
Whre is the hard drive located at in this device?
Did you add a hard drive? Unless the dealer who sold you the printer also installed a hard drive there is not a built in hard drive. The drive plugs into a EIO slot and kind of sticks out of the printer. I repeat none of the models ship with a hard drive, but one can be added. The EIO slots are on the back or the side. I do not remember off the top of my head.
Nov 18, 2010 | HP LaserJet 5550dtn Printer
Problem with the HP LaserJet 4050 Printer 82.0180
The 82.XX error represents that the External Card which is located in the formatter of the machine, either is bad or the port in the formatter is bad (This could be a Network Card or a Hard Drive really depends on your machine.)
Recommended Solutions:
Please make sure you turn off the machine before removing the card!
Remove the card from EIO slot 2 and plug it into the EIO Slot 1 is the card still does not work then the card will need to be replaced.
If both the EIO slots do not recognize the card. It's most likely the card, however it could also be the formatter.
Oct 20, 2010 | HP LaserJet 4050 Printer
Usb problem
no fear. sorry to say that your usb flash is done for. extracting the information can be done, but it is a specialized job and thus will cost a small fortune. getting it repaired is fairly simple but the information inside might not be attainable due memory chip damage. does your fash disk power up (as in does the light on it flash when plugged unto the USB port)?
babyvalkyrie. your problem is slightly different. what you need to do is log onto the bios menu during startup if the bios recognises the the HDD then you can try to re-install windows on it, but during setup you will have to formatt your harddrive fully (formatt using the long formatt not the quick formatt. also use the ntfs formatt. If your bios does not recognise your HDD then you will just have to replace it.
May 17, 2008 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
HP q6659a - Designjet Z3100 44-in Photo Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
