Picture works on t but there is no sound what is causing this? Tv is only 3 months old
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on Apr 11, 2015
  • 774 Answers
Take it back to where you bought it. It's under warranty why bother.
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
Our tv is about 3 years old. We are a Time Warner cable customer. About 2 months ago we started to notice that the picture took a ong time to appear after turning on the set. The sound played for about...
I'm sure this is fairly easy to repair. It sounds likely to be a power supply problem, possibly due to bad capacitors. Your original symptoms of no picture were likely to be the backlight controller not having sufficient power to operate correctly. Ideally you should have it looked at and repaired then because leaving it to get worse may well have caused additional component failure. Get it checked by a reputable TV repair engineer.
Feb 27, 2011 | LG 32LC7D Television
T.v.powers up, sound but no pic. t.v. is only 3 months old.
Tv have a dead long board call the LCD inverter board.This long LCD inverter board,help to get a backlight to the LCD screen panel,to produced a picture.Tv only 3 months old,take ur warrenty repair,call the Dynex corp. for warrenty repair.
Oct 16, 2010 | Dynex DX-L22-10A 22 in. LCD TV
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
NO SOUND GOOD PICTURE TV IS ONLY 5 MONTHS OLD
Unplug,replug the tv back about an hour later.Go into the tv menu,go to SOUND,go down to reset it to back to factory setting.The sound now should return,not,than ur tv the Tuner board have problems,call for warrenty serviced.
Jun 28, 2010 | Toshiba REGZA 47HL167 TV
No Picture on LG Tv. it is only 3 months old. I
The flashing may indicate a failed power supply. Or a bad backlight tube.
Only 3 months old? Any warranty?
Considering its age I would say a defective part or poor assembly is to blame.
Feb 05, 2010 | Gateway FPD2185W 21 in. LCD Television
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
No picture, sound works. Screen flickering
That problem is caused by the Y Sustainer board.
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Rca truflat with green tinted picture?
Just because a machine has failed, there is no cause for you to call it a stupid TV. And as it is only 6 months old, why not take it to the Company service Centre? There must be warranty.
Apr 01, 2007 | RCA 27F530T 27" TV
VIZIO 42" Plasma HDTV
i have a vizio p42 and i have sound but no picture i have tryed to reset it but nothing works
Nov 24, 2006 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
