Question about HP Computers & Internet
Why is this graphic card having trouble getting signal to my monitor
My computer is a hp windows vista ultimate
  • 5 Answers
#1
Windows Vista generally isn't supported by Microsoft anymore. Along with WinXP and anything before that.
#2 Depending on what kind of connecting cable you have and monitor, my suspicions are even those are outdated.
#3
It would be best to go to a Yard Sale or a Computer shop and buy a used system with at least Windows 7 installed in it. Even then, depending on when it was made it can be an old machine, just with win 7 on it.
Posted on Apr 17, 2015
Actaviosan
  • 100 Answers
SOURCE: NVIDIA GeForce 6600
Did you try installing and updating the driver of the graphics card dedicated to the operating system "VISTA" ? Sometimes there is some difference between vista's driver and XP's driver.
Posted on Mar 14, 2007
mtspace
  • 103 Answers
SOURCE: No signal to monitor
  1. Verify card is seated properly.
  2. Check bios settings. ie. disable onboard video, enable PNP OS installed, enable "assign IRQ to vga", disable shadowing and caching, enable passive release, enable delayed transaction, vga boot sequence: AGP, set graphics aperture size to 128MB, disable turbo modes.
  3. Verify power supply is at least 350 watts.
  4. Reboot into safe mode (press F8 right after the BIOS POST screen and before the windows loading screen) and use the program, Driver Cleaner Pro to remove Nvidia video driver remnants. Don't select all of the options, just the Nvidia driver and the plain ATI selection.
  5. Verify the monitor cable is securely connected to both the monitor and the computer.
  6. Verify that you have connected the cable to the vga port on the card and not the onboard vga port. (I'm not implying that you are dumb or anything like that, but sometimes even the best of us, overlooks the simple things... especially me! LOL)
  7. Verify the monitor cable is good.
  8. (Last but not least), try using another monitor to test. (Could be an incompatibility with the monitor.)
Posted on Jan 02, 2008
jasonkoe
  • 64 Answers
SOURCE: Need to update my graphics card
anything modern should be able to handle that resolution. should say on the package what the max reso is and if its over what you need id say its a safe bet. That card your using is really old and out dated. i dont even think you can by cards that have less then 128mb of vram on them anymore.. hope this helps, good luck.
Posted on Jan 22, 2008
SOURCE: ATI 256MB Radeon X550 Graphics card
hi plz how is the proessor of drivers
Posted on Apr 15, 2008
odiebugs
  • 949 Answers
SOURCE: I need a Vista driver for Appian Graphics Rushmore Graphics Card
Look at your motherboard spec's and see what you have for a video card slot, then see what chipset
is running your board, if the chipset is ati then get an Ati card,if nvidia,then nvidia card.
I have never even heard of these card MFG, and don't see there support sites.
My opinion would be to go to a place online like Newegg.com and find a card for your board, a good cheap card will run about 30-40.00 dollars. The graphics will be a lot better on your pc.
If the cards came with the pc,you can try and go to the site of the pc maker and see if there is a vista driver, if not, you either have to reinstall xp or buy a new card. Hope it works out.
Posted on Mar 21, 2009
What is dvi no signal
Digital video input no signal,on a monitor usually indicates that the video cable is not supplying a signal.Could be a faulty cable, or a bad connection from computer or the monitor...or a bad display driver / faulty video card.check connections ,try with different cable and monitor.
Feb 11, 2015 | Microsoft Windows Vista Ultimate Edition
Hp 1740
You might need to replace the sound card or download the audio drivers for your motherboards audio.
Apr 16, 2014 | HP Audio Players & Recorders
I can't connect an external HF199H monitor, on a 2007 MacBook 3,1 running Windows 7. Help??
ok so for clarification, you are using a MacBook w/ a dual boot to windows 7 Ultimate? and after the update from Vista it now is not detecting your external display.
If I am correct, your graphics card is most likely an NVidia chip set. Do some research and find your specific graphics card, go to the NVidia website and download the most up to date drivers for it and try again. If you have done this already, try emailing them and find out if your graphics card is compatible w/ windows 7 or if the driver was specifically designed for vista. That's where I would start.
Jul 03, 2012 | Hannspree HF199H 19 Flat Screen LCD...
I can only get 480 x 640 resolution and 4 bit colors and all the graphics are fuzzy
It appears the graphics card driver has not been installed. Check the device Manager and if you get a yellow ? against the Display Adapter then you need to install the graphic driver.
If your computer is a Compaq or HP then you need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model computer and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
If your computer is not a Compaq or HP desktop computer and you know the make and model of the graphics card in your computer then go to the graphics manufacturer's WEB site to download the graphics driver.
Sep 30, 2009 | HP Pavilion M90 Monitor
Built in windows vista in acer pc recovery
your display graphics is in trouble but not actually the Physical VGA Card, only in the system.. if you still have that problem then reinstall your system again.
Jul 22, 2009 | Microsoft Windows Vista Ultimate Edition
Hello, I have a HP 22w LCD monitor, running
Can you try the monitor on another computer? Also, make sure the cable is tight on the monitor side. And you also may need to replace the cable between the monitor and the computer.
Jun 13, 2009 | HP dx2300 Monitor Personal computer Intel...
No Signal and BIOS troubles - new video card
try using the onboard graphics instead and remove the graphics card. then uninstall all the graphics card drivers and software and reinstall again. make sure you install 32bit or 64bit depending on what your operating system is. you can find out if it's 32 or 64 bit in the welcome center of vista.
Apr 05, 2009 | Acer X193W LCD Monitor
Issue with 20" WideScreen Monitor
I think you are having trouble with the plug the cable connects to.
Jul 09, 2008 | HP L1955 19" LCD Monitor
Graphics card for HP slimline 3300t PC
troubles and tribulations of the compaq approach to board level expansion bus cards..been like that for millenia...
what kind of monitors you using?
Feb 19, 2008 | Computers & Internet
Display adapter
if you know the name of graphoc card search driver or update for vista bcoz the driver which was installed it is not comaptible with vista go thru the make and manufactrer list and download the driver for windows vista. if you not able to search the driver or driver for windows vista is not available then you need to change the graphic card. bye
Sep 05, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
430 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
