Question about Hoover Vacuums
Hoover spin scrub 50 water drips from hand tool port but there is no pressure thus no spray. So what to do?
5 Suggested Answers
galati2k
  • 281 Answers
SOURCE: The tool attachment won't spray water-
you almost have to open up the unit and follow the hoses from the handle into the base.fill it with solution and turn on pull triger.hold the triger in and turn off the unit keeping the triger pulled.turn off and start it up and try again.if it don't spray you might have a bad pump.open up the unit and see if all the hoses are hooke up.there should be a plug on the handle .is it plugged in.please leave feedback.i hope i was some help to you...pet
Posted on Apr 30, 2009
renevacdoc
  • 84 Answers
SOURCE: spin-scrub brushes do not spin
hello. there is a little window by the brush control. if you open it up, you can see that there is maybe some lint covering it. scrape that off, and try again. make sure your lever is set to brushes and realease the handle release. if this doesn't work, then you probably have a problem with your gear box. this can only be serviced at a repair shop. I hope this helps. Let me know! Thanks, Renevacdoc
Posted on Jul 24, 2009
fixdat22
  • 34 Answers
SOURCE: my hond spin sprayer on my Hoover Legacy series
it is clogged. the hose part were it sprays is most likely to be clogged with debree. It happens all the time with hoovers
Posted on Sep 12, 2009
SOURCE: my hoover steamvac turbopower 5000ls will not spray for hand tool
my turbo 5200 will not pick up the moister into container to dry does anyone know what the problem may be
Posted on Mar 06, 2010
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
How do I hook up the upholstery attachment on a Hoover Spin Scrub 50?
To connect the upholstery tool, first remove the clean water tank by pressing down on the handle and pulling the tank forward. Remove the hose from the storage rack. Press down on the handle release lever and lower the handle to the ground. Unlatch the back part of dirty water tank and remove the lid. Pull the dirty water tank's front panel up about an inch and rotate the panel to parallel with the floor. Replace the panel with the converter and slide it halfway down until it is firmly in place. Pull the collar on the connecting tube towards the tube so that the black tabs are fully extended. Open the door on the hood labeled Stair/Upholstery cleaning connection and press the round solution tube onto the round projection. Press the collar firmly to ensure that the tube is connected. Replace the tank in a hinge-like manner and place the lid under the tabs on the front of the tank. Rotate the lid down onto the tank.
Now slide the upholstery tool on the connector of the hose until the tab locks into place.
The manual for the Spin Scrub 50 is available on the Hoover product page: http://hoover.com/products/details/fh50044/steamvac-spin-scrub-50-carpet-washer-with-tools/ . The direct link to the manual is http://hoover.com/file/1195/ . The directions are on page 14-15.
I hope this helps.
Oct 19, 2015 | Hoover Vacuums
Why it won't pick up water?
Make sure the switch is on the setting you are using, I.E. spin scrub. If this isn't the problem you may have a bad turbine blade, if the scrubber brushes aren't turning that is your problem. $45, a screw driver and general mech. abillities will fix it. http://www.vacpartswarehouse.com
Jul 21, 2014 | Hoover Spin Scrub 50 Deep Cleaner
The cleaning solution nozzle on the Hoover Spin Scrub upholstery attachment just barely drips. I can't get the solution to spray. Any ideas?
make sure that the supply line is clear ,some times if solution is allowed to dry in the line the soap dries and blocks the route of solution
Try and use some viniger to break up the deposits
Jul 08, 2011 | Hoover Vacuums
My hoover steamvac turbopower 5000ls will not spray for hand tool
Sep 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover spin scrub machine has stopped scrubbing. It still dispenses and pulls up the water, but the brushes don't move. I've checked the on off button for brush control and cycled it to off and back on,...
There is a filter on the front right hand side of my F5871-900 Hoover. If you remove the plastic covering and clean that filter (wet finger may do), you're Hoover will begin spinning again!
Jul 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5858-910 doesn't spray water
Hello dc42 & osuguy101. I suggest using a cleaning solution, 50/50 vinager/water, in the fluid tank to clean the ports. #2 Unit may have a fluid pump problem. Please update me on results.
Sep 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
