Question about Sewing Machines
When I start to sew the machine will make a humming noise then I have to turn the wheel until I get through a stiff or hard part. Once I turn it enough then it will start to sew again.
  • 1,631 Answers
Older machine?
Common, the motor is tiring. When fabric is too thick, the machine will labor to get thru the fabric. A good appropriate needle, Sharp Needle, will also help out this problem. But as long as you can manually assist, then you are still fine. Regular machine maintenance will prolong life of your machine.
Posted on Apr 11, 2015
  • Sewing Machines Master
  • 8,899 Answers
If it is an older mechanical machine, the oil may be drying out and the moving components are sticking. This causes your motor to bog down trying to move the components. If you have not cleaned and oiled your machine recently, it might be a good idea to consult your manual and apply some good quality sewing machine oil. If you don't know how or are afraid, then take it to a sewing machine technician.
The other option is your fabric is too heavy for your machine. It may help to use a new sharp needle that will better pierce the fabric.
Posted on Apr 13, 2015
  • 30 Answers
SOURCE: Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Posted on Jan 24, 2009
  • 98 Answers
SOURCE: needle doesn't move
the problem is some fabric, dust or thread is stuck behide the plate that holds the sewing needle and foot.
Posted on Mar 10, 2009
  • 323 Answers
SOURCE: Sewing machine motor may have seized up
The oil and grease in your machine has turned into a very sticky, syrupy mess and needs to be chemically removed . My guess is that even if you were able to get the machine to turn freely it wouldn't zigzag . I really recommend that you take the machine to be professionally serviced again and do not let it sit idle.
Once it is serviced,test it before you bring it home again. These things are kind of tricky sometimes.
sewman7
Posted on Apr 06, 2009
  • 10 Answers
SOURCE: Husqvarna Sewing Machine starts sewing when power switched on
The problem is probably the foot control. The little wires wrapped around the insulator have broken and are shorting against each other or the cord itself has a short. You can purchase an aftermarket foot control at your local shop, this is the cheapest way to try first, if that does not correct the problem replace the cord.
Posted on Jun 30, 2009
  • 1564 Answers
SOURCE: The hand wheel is hard to turn and sticks on my Euro Pro x 8260 sewing machine and I need the manual
Can't help you with the manual. I've never found a source for a free one. As for the issue with the hand wheel ... that is usually a sign that your machine needs cleaning and servicing. (typically fluff, lint, threads, not enough oil, etc.)
Posted on Sep 01, 2012
The hand wheel has become so stiff it wont sew....however, when I put it in bobbin loading position, its normal. Any thoughts?
If your machine was serviced a year ago and you use it extensively, it is probably due for another service. Recommendations are once a year.
Consult your owner's manual. Sounds like it probably needs cleaning and oiling, especially since you said you use it a lot. They do need some periodic TLC to keep them operating well. Mechanical machines, especially, do need maintenance. (You wouldn't run your car without oil.) The fact that the motor is straining but things are not moving is a good indication that it needs some attention. Do NOT run the motor if the machine is frozen--you could burn up the motor or cause other damage!
Sep 27, 2016 | Singer CG-590 Commercial Grade Sewing...
Brother sewing machine cs6000 hand wheel hard to turn by hand
before you race the machine into a service centre, most hard to turn problems are from thread and fluff wound around the bobbin shaft in the base of the machine. Use a pin/ needle to remove the thread /fluff then oil the machine using light machine oil. If it is still stiff , take it to a service centre.
Jan 31, 2015 | Brother Sewing Machines
How do I get a Service manual for an Industrial Sewing Machine
If the handwheel is really stiff and the machine is making awful noises, then your machine may need oiling. Don't know if this is the case with your industrial machine, but it may be something to consider.
Jun 12, 2014 | White Sewing Speedylock 1600 Mechanical...
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Hand wheel & needle very stiff
Hai, I think your machine timing is changed. So you can't sewing properly. Please check the timing and put the oil everyday all oil parts properly.
Apr 16, 2014 | Singer 1507
The wheel on my Singer overlock is hard to turn and its making a lot of noise.
when a machine starts making noise then the machine needs to be check to see why
May 21, 2012 | Singer 14SH654
Motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
Mar 18, 2012 | White Sewing Sewing Machines
Athena 2000 humming & then poping and sputtering noises
Be very scared and take it to be seen to by a service technician...lethal current here !
Nov 04, 2011 | Sewing Machines
My machine started making noise and the handwheel became hard to turn. The hand wheel stopped turing completely. can I fix this myself or does it have to be repaired professionally?
Take the bobbin case out completely to begin witgh and check for any jammed thread, see if you can turn the balance wheel once the bobbin case is out, if you have a front load bobbin take the raceway out as well, if it still does not move you have a problem which will need shop attention
Sep 05, 2011 | Singer 2263 Mechanical Sewing Machine
I have had this machine since i was 10 and im 16 now. i dont remember how to start.. i have the needle loaded and the bobbin loaded, whats next?
Rotate the wheel until the bobbin thread is picked up. Once the bobbin thread is up, you can start sewing. Be sure to turn the machine on.
If the machine is making noise, unscrew the top and/or bottom plates and oil any place where metal rubs on metal.
May 27, 2011 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
59 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
