Question about Dishwashers
Only worked during toast cycle,now doesn't work at all
    Genius:
  • 1,167 Answers
You have a toaster dishwasher?
Posted on Apr 10, 2015
Why would the cruise control quit working it just turned off during a trip,,all three brake lights are working,,did find the 3rd brake light really toasted.
I am not sure why but I had the same trouble with my Ford and when I replaced my turn signal wire and connector on the left rear the cruise worked good. It would work then just when I hit the turn signal to pull out and pass the car automatically would slow down. My wire was toast as well.
Sep 29, 2015 | Cars & Trucks
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
My Amana washer doesn't aggitate during wash cycle
What is the model number of your unit?
Nov 30, 2012 | Washing Machines
Will not shut off.
Your timer is broken, kind of like mechanical watches and grandfather clocks, and music boxes.... If you over wind they no longer work properly or at all. The coild that stops and starsts it doesnt lock any more and now it doesn't know when it is technically done. SO my dear, you now have the best, awkward toaster oven :]
Jan 07, 2012 | GE Toaster Ovens
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
No power
The main PSU is part of the control board. You may be lucky to find an aged fuse to replace, but it's more likely a power transistor that's fried.
Unplug and remove the control board to see which bit's toasted. Chances are it's cheaper to replace the control board - but check the probable cause - the motors are not short circuited.
May 02, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
My Frigidaire front loader washer makes a very loud knocking sound during the spin cycle before the final rinse. It intensifies the longer I allow it to spin. I have to shut it off before the cycle is...
from your description, it sounds like your washer is already broken - to check, open the door and reach your hand into the tub at the front top. push up. if the tub moves more than a fraction of an inch, the bearing and/or spider are toast. last time i checked, the PARTS were in the neighborhood of $450 and it's a BIG job! [read that: big labor bill]. this is a common problem with these machines and it's probably time to get a new washer. sorry!
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Inglis Washing Machine agitator not working right
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
Will not start wash cycle
The circuit boards on these types of units are kind of finicky. If there is any seepage of the steam generated by washing that gets into the door skin, then it can toast a circuit in no time flat. It is more than likely the momentary switch but the only way to find out is to remove the inner skin, pull the board, and look for toasted components and check continuity through said switch.
Jan 28, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
Owen Barnes
