Use to work only on toast cycle only.now it doesn't work at all
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inter lock
Posted on Apr 16, 2015
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
I jumped a truck off this morning ever since my jeep doesn't want to start why?
I would check for power at the starter, you may have toasted a fuse or a fuseable link.
Aug 28, 2012 | 2006 Jeep Commander
Will not shut off.
Your timer is broken, kind of like mechanical watches and grandfather clocks, and music boxes.... If you over wind they no longer work properly or at all. The coild that stops and starsts it doesnt lock any more and now it doesn't know when it is technically done. SO my dear, you now have the best, awkward toaster oven :]
Jan 07, 2012 | GE Toaster Ovens
Doesn't bake anymore. Will toast only. What is wrong?
The main switch is probably fried.
http://www.google.com/url?sa=t&source=web&cd=2&sqi=2&ved=0CCQQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D0H_2xkHX2MU&rct=j&q=dead%20B%26D%20toaster%20switch&ei=TDPsTfCzIsj40gHt_t20AQ&usg=AFQjCNH-29MMcdG4-dvG5BaUMoHwmdGJHw&sig2=TAo2lyiw4kl3sjH8n650vQ&cad=rja
http://www.google.com/url?sa=t&source=web&cd=1&sqi=2&ved=0CB0QtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DFpCEjqsz1Bo&rct=j&q=dead%20B%26D%20toaster%20switch&ei=TDPsTfCzIsj40gHt_t20AQ&usg=AFQjCNGFR3WEyLDELaHhTSilqPBn4KosFg&sig2=UMJZuhN7h7DYKTiCQb8Ubg&cad=rja
May 10, 2011 | Black & Decker TRO651 Toast-R-Oven Toaster...
I accidently droped the mp3 player in water and its not comming on the charging bar keeps on going from full to empty rapidly and the buttons are not working.
electronics that have been dropped in water should be taken apart immediately, allowed to try with a fan on them for 2 or so days, reassembled and then attempt to charge. If this doesn't work- sorry, but it's toast.
May 05, 2011 | Health & Beauty
I recieved a B&D 4 slice toaster in November 2010. chrome and Black. Toasting bread is a 20 minute ordeal. I DOES NOT TOAST. Set at the highest setting, I like my toast very brown, and even if you...
If it doesn't work like it should, by all means - return it for a replacement or refund. With that said, I have another possibility.
As an electrician, I have seen pretty strange things that seemingly defy explanation. There may be an issue with the outlet or circuit(s) in the kitchen where this toaster is being used. Try plugging this toaster in a plug in a different room of the house. Do not try it in the kitchen, but in the dining room, basement - or some other room instead. If it works as expected, there's an issue with the plug / circuit that you are using. You ought to have that checked out sooner rather than later.
I hope this helps and good luck. Please rate my reply - thanks!
Apr 20, 2011 | Black & Decker Toast-It-All Plus T4550...
I have a kenwood toaster it keeps popping up every 2seconds or less what could be wrong
It could be your browning control is not working or it needs to be moved to a darker setting.
I could not find the instructions for your specific model but in order to achieve uniform browning it is recommended you wait a minimum of 30 seconds between each toasting to allow the control to automatically reset. This could be the problem if the first cycle of toasting completes correctly; you need to wait the minimum 30 seconds before starting a second cycle.
If the product is less than a year old and under certain condition Kenwood will replace.
Contact information: http://www.kenwoodworld.com/uk/Customer-Service/
Feb 03, 2011 | Kenwood TT890 2Slice Toaster
Can you turn off the annoying beep when toast is
Hate to tell you this, but from the looks of their manuals on the similar Australian model, then no.
"When the toasting cycle is complete, the toaster will ‘beep’ to indicate that the toast is ready. No need to wait while the toast cooks."
Dec 03, 2009 | Breville CT75XL 4-Slice Toaster
Will not start wash cycle
The circuit boards on these types of units are kind of finicky. If there is any seepage of the steam generated by washing that gets into the door skin, then it can toast a circuit in no time flat. It is more than likely the momentary switch but the only way to find out is to remove the inner skin, pull the board, and look for toasted components and check continuity through said switch.
Jan 28, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
