Question about Garden
Blades stopped after being stuck in mud tr/mwf lt200 snap 42" B&B into twin
    Top Expert:
  • Garden Master
  • 44,312 Answers
Probably burnt the belts off .
Posted on Apr 10, 2015
2 Suggested Answers
SOURCE: how do I raise the blades
there should be a big bar on the right side of the mower that changes the deck height. if it only going up a little look for a height limiter dial on the other side of the mower about where the height adjustment bar is on the right side.
good luck and be careful!
Posted on Jul 01, 2010
Testimonial: "Thanks. I know it was a ridiculous q, but the brain was having trouble recalling the info after intense round of chemo. So, thanks for answering w/o condescension."
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Apr 23, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Only after i got stuck in mud did blades on snapper lt 200 42 rider so working belts are tight must be sensor insert seat went out or went bad
Blades would not turn after I got stuck in mud. Electric clutch?
  • Turn the engine off and remove the key.
  • Check for physical damage; anything look bent?
  • Spin the pulley on the bottom of the clutch. Does it spin freely?
  • There could be mud or grit stuck in the clutch.
  • There is a drive key between the clutch and the shaft. Has this key been sheared? It's possible the clutch was burnt out during the mud incidence.
PTO Clutch will not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
  • It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 10, 2015 | Snapper Garden
Blades won't engage after got stuck in mud electronic pull on blade engagement
Blades would not turn after I got stuck in mud. Electric clutch.
  • Is the deck belt intact?
  • When you pull the PTO switch does the clutch make a "click"? It's possible the clutch was burnt out during the mud incidence.
Apr 10, 2015 | Garden
Pull switch on blades but they won't engage worked fine until i got stuck in some mud now won't engage
M SNAPPER LT200 STOPS RUNING WHEN I TURN ON THE BLADES
check the safety switches with that problem look at the one on the seat
Apr 02, 2012 | Snapper 20 HP Lawn Tractor 2690578
How do I raise the blades
Jul 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a murray riding mower with twin blades..how to change
take a socket rench with 2 feet pipe....slide the rench handle to the pipe and that well give you enough power to turn you have to hold the blade with something from turning .....ometime you can hold it with a towel
Oct 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
