Question about Snapper Garden
Only after i got stuck in mud did blades on snapper lt 200 42 rider so working belts are tight must be sensor insert seat went out or went bad
    Sergeant:
  • Snapper Expert
  • 187 Answers
Blades would not turn after I got stuck in mud. Electric clutch?
  • Turn the engine off and remove the key.
  • Check for physical damage; anything look bent?
  • Spin the pulley on the bottom of the clutch. Does it spin freely?
  • There could be mud or grit stuck in the clutch.
  • There is a drive key between the clutch and the shaft. Has this key been sheared? It's possible the clutch was burnt out during the mud incidence.
PTO Clutch will not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
  • It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Posted on Apr 12, 2015
wadembly
  • 489 Answers
SOURCE: problem replacing belt on a ols rear engine snapper?
what kind of mower & model # i may be able to help thanks wade
Posted on Jul 04, 2009
  • 138 Answers
SOURCE: broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Posted on Aug 15, 2009
  • 110 Answers
SOURCE: VIBRATION-THRU SEAT & FOOT RESTS AFTER ENGAGING BLADE
get down and gun your fingers in the slot that the belt rides in, soulds like you may have a small rock or piece of wood lodged in the v part of one of the pulleys. I bet thats it Jim
Posted on Dec 19, 2009
  • 16 Answers
SOURCE: Snapper Zero Turn mower. Blade will not engage. Any suggestions?
I am not sure what type of blade engagement mechanism you have (ex. clutch, tensioner/idler pulley, etc...) but make sure that the blades can spin freely with the belt taken off of their pulleys. It could very well be that one of the pulley bearings is seized.
Posted on May 07, 2010
  • 3074 Answers
SOURCE: hi, i have an snapper riding lawn mower model
http://www.ehow.com/how_6402951_change-snapper-mower-belt.html
Posted on Apr 03, 2011
Snapper 1642h rider does not self propell belt is intact
The belt may worn. Check to see if there is slack in belt. You did not say if blades were turning. Also what is the complete model number. Number is not found in online manuals. Thanks and let me know.
Jul 04, 2017 | Snapper Garden
On the Zero turn mower , how do you relieve the air in the pump lines after replacing a bad pump . Please advise.
How To Release Pressure From Fuel Lines - YouTube
? 0:51
www.youtube.com/watch?v=6oo9zlTMPOQ
Oct 15, 2009 - Uploaded by YeechBlitz
See a demonstration on how to release the pressure from fuellines of a 1997-2000 ... in the tank, but do not let the air out, so pressure can build up in there. ... Diesels is where you want to be extra careful, the injector pump to ...
5900748 Snapper Zero Turn Mower - Hammerwall
www.hammerwall.com/.../Snapper/.../5900748/Snapper%20Zero%20Tur...
Back To Snapper Tractors-Riding-Lawnmowers Model: 5900748 Snapper Zero ......Reinstall each mower blade with the air lifts pointing up towards the mower deck ... The fuel filter is located in the fuel line betweenthe fuel tank and fuel pump . .....TROUBLESHOOTINGTHE RIDER PROBLEM CAUSE REMEDY Enginewill ...
Sep 25, 2015 | Briggs & Stratton Snapper 5900748 355Z...
I have an LT series Snapper rider with 20 hp and 44" cut. The transmission seems to be slipping. I have not checked the oil. Replacing the belt looks like a big job.
Not as some John Deere mowers I worked on lately.
I am assuming your is the Hydro version with electric pto. First set the parking brake as this remove tension on the belt.
You will need to remove the pto clutch and attention to the keys are positioned as they are one way keys. When reinstalling the PTO clutch it torqued to 55 ft lbs. To do this you need to remove the engine shroud so can block the flywheel movement.
The rest of the belt removal and replacement is fairly straight forward.
May 06, 2015 | Snapper Garden
Blades won't engage after got stuck in mud electronic pull on blade engagement
Blades would not turn after I got stuck in mud. Electric clutch.
  • Is the deck belt intact?
  • When you pull the PTO switch does the clutch make a "click"? It's possible the clutch was burnt out during the mud incidence.
Apr 10, 2015 | Garden
Pull switch on blades but they won't engage worked fine until i got stuck in some mud now won't engage
Grease plug locatiom snapper rider
if it's a rear engine rider with a 28 or 30 inch deck the grease fitting is underneath the deck... If it is a rear engine rider, close the fuel off and stand the mower on end but for a short period of time only. This applies to ALL rear engine riders from Snapper up until about 2 years ago when they made a SERIOUS mistake and redesigned them
Sep 11, 2014 | Snapper Garden
Belt diagram for snapper lt 200 riding mower
PLEASE SHOW ME A DIAGRAM OF ACTUAL BELT AND PULLEY'S FOR SNAPPER LT 200, MODEL #2690441?
Mar 12, 2011 | Garden
Garden Logo
104 people viewed this question
Top Snapper Garden Experts
ray gallant
solver2010
Thomas Perkins
Thomas Perkins
Are you a Snapper Garden Expert? Answer questions, earn points and help others
