How can I unlock my DEFY maximaid 800 front loader mid cycle? (no water in the drum yet) Thanks
    Top Expert:
  • Washing Mach... Master
  • 46,218 Answers
Some washers have a manual release under the top .check your manual
Posted on Apr 10, 2015
IB4G2008
  • 3587 Answers
SOURCE: stops mid cycle
that's the washing machine version of going on a walkabout, no? just kidding.
E9 suggests that the line is getting clogged. the filter pulls out(see user manual for that option) and you might want to consider running it with baking soda solution in warm water or hot, once or twice to get rid of that odor.
Posted on Mar 11, 2008
docjohn174
  • 943 Answers
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
SOURCE: Water stays in drum after cycle is complete and odor
I think from what you have said, that you have a pump problem. The water pump on most washers collect all sorts of bits and pieces including small coins. You may be able to clean out the pump if it is not a sealed unit.
Posted on Dec 02, 2008
mpcheeseman1
  • 1400 Answers
SOURCE: The washer leaves water remaining in drum after
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
Posted on May 13, 2010
tbirdfan1
  • 3051 Answers
SOURCE: front loader wont spin
Hello there:
It doesn't spin If your washer won't spin, check these: If the motor is running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
Posted on May 15, 2010
Defy maximaid 800 error code E8
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Jun 20, 2016 | Washing Machines
Defy Laundromaid 1300 making grinding noise while washing,how do i remove pulsator to see if there is something in it
if the grinding noise is more pronounced at spin cycle , it could be the drum it self, if the grinding noise is there constantly, could be the bearing to the drum. front loader. easy to fix, let me know..
Apr 14, 2014 | Washing Machines
Water sounds drum
This Liquid in the drum to balance it on spin, all Maytag front loader have it.
Dec 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
I want to open the door mid cycle and restart it. Instead when I push pause the door remains locked and I can't insert another item without draining the water and starting over.
Yes that is how that style washer works since its very possible if opening the door when water is in the tub that it would spill out when opening the door when water in the tub..all front loaders work ina similar manner where when water is in the tub the door wont unlock
Aug 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi - My Whirlpool washer appears to not use enough water. Don't get me wrong, I want the machine to use low water (that's why I bought a front loader, model: WFW97HEX). However, when I stop the...
Don't pause the cycle mid cycle. The machine uses the amount of water it needs to clean the amount of clothes that are in the tub. If you pause it after the first 7 or 8 minutes, you're already past the sensing part of the cycle and likely you won't get more water for the additional clothes.
Also, the clothes don't need to be soaking wet or wet enough to wring out. These new HE machines mix the detergent with water and then spray that detergent solution onto your clothes. Then the clothes against clothes rubbing with that solution already coating the clothes is how the machines clean better! It is a very similar process to when you pretreat your clothes with Shout of Spray and Wash. You spray the clothes and then rub the short against itself. Now the Whirlpool machines are doing this for you!
Aug 30, 2011 | Whirlpool WFW97HEX Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Problem with whirlpool front loader
Your water mixing valve is letting water in the machine between cycles. That is the valve that the hot and cold water hoses connect to in the back. Replace that valve to stop the water build up. Run a periodic cleaning cycle with a generous amount of white vinegar to rid the smell. Or you can buy a prduct called Affresh from a hardware store.
Jun 21, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
269 people viewed this question
Top Washing Machines Experts
