Question about Amazon Kindle Fire HD 8.9"
Will not connect to wifi - Amazon Kindle Fire HD 8.9"
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
I can't connect to wifi and when I can I can't setup my gmail account or any other apps I have try everything I know
I'll give you some help on ANDROID. Go to apps, settings\ WiFi. Turn it on at top of screen. Any available WiFi accounts will show up. Then go to top right push the three dots, click advanced and make your choices. Click back to WiFi screen and click the WiFi you want to connect with, enter the key that your WiFi needs to connect, or use the WPS option if available on you WiFi. If the WiFi has WPS, push the button on the WiFi and connect your tablet or phone by pressing connect.
Nov 29, 2015 | Tablets & eReaders
My Kobo Arc 32, asked for a password, when I tried to try the WiFi. I don't remember setting a password. So, now it's asking for an guest password.
It is not the Kobo that has set the password, rather the router for the wifi that you are trying to connect to. You just need to know the password for the router to let you connect. If a router has no wifi password, it is considered unsecured and ANYONE can access it. So most all routers use password protection. If it is YOUR wifi system, and you no longer know the password, you can change it if you access the router setup for wireless and change the password. Be advised, however, that all devices that connect to the wifi will need to change their passwords as well or not be connected. If it is not your wifi you are trying to connect to, then you need to obtain the wifi password from that wifi system's administrator.
Nov 06, 2015 | Tablets & eReaders
Why can't I access internet?
Restart your device.
If it is your WiFi, unplug everything involved with it for 30 seconds and then plug it all back in.
Make sure wifi is turned on.
Make sure that you are trying to connect to a WiFi signal that you know you can connect to. Not all WiFi signals are ones we can connect to with our tablets, phones, and computers. Try connecting to another signal, or try having another device connect to the one you can't connect to to see if it is a device trouble, or an individual WiFi signal issue.
Nov 02, 2015 | Tablets & eReaders
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
I can not connect wirelessly
I have had this problem before and I had to go under WiFi settings and forget my WiFi. I let it scan again for service and reentered my WiFi network information. This worked for me most of the time. However, it could be your WiFi itself. Can you connect anything else to your WiFi?
May 15, 2015 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
I can not connect to the internet with my zeepad. I bought both of my daughters the same model tablet and they can get on the internet with their tablets.
Most tablets connect to the internet through WIFI. Only a few can use SIM card to connect through 3G or 4G data connection. For WIFI connection, you must have a WIFI router at home. You will normally password-protect the WIFI rounter. To connect the tablet to the internet through the WIFI-router that is in operation, you will configure its WIFI settings to match the router's password. This will be done by going to tablet's Setting, turn on WIFI, click on your router in the list of detected routers, enter the password when prompted. Ensure that Connected is shown against your router. You can then browse the internet.
Jan 10, 2015 | Tablets & eReaders
Amazon Kindle Fire HD 8.9" Logo
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
