Question about Kenwood KDW60X13 600 mm Stainless Steel Freestanding Dishwasher 14 Place Settings, A Energy Rating
Detergent chamber does not open during wash cycle
The fabric softner isn't draining during cycle but the bleach and detergent do just fine. I took out drawer and cleaned the dispenser but still won't empty. Help!
When cleaning the softener chamber, make sure you remove and clean the syphon tube thoroughly. This is the only chamber designed to handle liquid. Otherwise, check that you have sufficient water pressure and that the cold valve opens fully. If you dont hear a decent gush of water during the rinse cycle, it's either pressure or the valve.
Dec 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Detergent dispenser on SMEG DWF 44SS1 doesn't open during cycle - any ideas?
this is Usually caused by a tablet sticking in the Detergent Dispenser. This will stop the Detergent Dispenser from opening at the correct time on the wash cycle.
Oct 18, 2009 | Smeg 24 in. DWI612 Built-in Dishwasher
Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Dec 24, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The clean pump light comes on after a wash cycle or spin cycle
The Air Chamber for the Pressure Switch was blocked with liquid detergent and grease.
When I examined the machine I could see that the underside of the drum, plumbing and door seal was contaminated with mould, liquid detergent and grease.
This problem is thought to be caused by using a low temperature wash and a liquid detergent without bleach. This problem can be prevented by cleaning the washing machine once a month with 50grms of Soda crystals or one cup of distilled white Vinegar using the hottest wash cycle. Do not put clothes into the machine during this wash.
Nov 04, 2008 | Whirlpool Washing Machines
Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Nov 17, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Detergent will not dispense during the wash cycle
Something simple you can check is to make sure the spring that flips open the door is not broken or caked up with detergent.
As for the soap not dissolving, I've had similar problems and the only solution I've found is to make sure you are not blocking  the spray jet on the bottom from hitting the soap drawer.
Oct 26, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Kenwood KDW60X13 600 mm Stainless Steel Freestanding Dishwasher 14 Place Settings, A Energy Rating Logo
53 people viewed this question
Top Kenwood Dishwashers Experts
ashburton
Owen Barnes
ray gallant
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
