Question about Garden
Snowblower will not move forward or in reverse.
It is a Snapper L1227e and the shift lever will not move at all.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Tilt it up on the Auger and take the bottom cover off.
The Friction wheel might be rusted to the Shaft.
Posted on May 12, 2015
My craftsman snowblower runs fine but will not move forward when I engage the lever. It will move forward only when I press both turn levers.
turn levers disengage wheels so tip it on its nose and remove bottom plate inspect the drive wheel and axles, pull levers to see what moving and what isnt
Jan 18, 2018 | Craftsman Garden
Car will not drive forward or reverse after shifting.
Make sure the shift cable hasn't come loose from the mechanism on the transmission and that it's moving as it should when the shift lever is being moved.
Feb 19, 2015 | 1993 Mercury Tracer
Isuzu rodeo will not go into reverse
bad shift linkage.
replace bad parts.
Aug 24, 2014 | 2000 Isuzu Rodeo
Problems shifting toro power max 726 oe snowblower
adjust the cable easy to do , get the manual or just look good at it ,
Feb 04, 2014 | Toro Power Max 726 OE Snowblower - 37771
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
1999 FORD EXPERDITION TRANSMISSION WON'T MOVE FORWARD BUT MY REVERSE WORKS FINE WHAT I NEED TO DO
You can try shifting into manual 1 to get moving then once you get going shift the lever up into Drive. This should work, then drive it to a shop to have your ****** looked at.
Feb 08, 2012 | 1999 Ford Expedition
Hi, I was working with the snowblower and suddenly it stoped moving forward and backword. how can i resolve this. jamie
ok....ummm...lol...(What we are going to do is check the "THROW".of the "shifting lever" ( the FWD*NEUTRAL*REVERSE LEVER(handle)).....""Look at your linkage"" ...if it is a solid rod that connects the "shifting lever" with the transmission (make it go thingy), often times down near the transmission (where the rod goes to from the "shifting lever"))there is a short slotted bar that rocks back and forth on a "pinion" (rocking thing) .... look where the long rod (from the lever) connects to the short "rocking" arm (from transmission)and see if it has slipped...this will sometimes show by a shiny spot where the rod used to be fastened...simply loosen lock-nut and reposition where it used to be..then re-tighten....(we are trying to increase how far the short rod moves when you change gears from Forward to Reverse)......on some models this same rocking motion is adjusted up on top by where the "shift lever" is..look on the under-side of the "shift lever"..(which is attached to a "mounting" plate that connects to the handles together) that is mounted on a "pinion" bracket ) and sometimes there is a slot under side of the shift lever ...here there could also be a shiny spot where the rod used to be attached..reposition where it used to be..or move until sufficient "THROW" is acheived to shift gears from forward to reverse......""IF"" it is a "housed cable" that attaches the "shift lever" to the "transmission"..then there may be a broken or loose "bracket"..or a "return spring" on the bottom that has come loose or fallen off...If these options dont help..then it may be the "engage"..or "clutch " that has issues...a little deeper problem... (if you print this answer and read it "while" looking at snowblower and touch the parts that i physically desribe when they are mentioned it will be much less confusing...mechanicking is difficult to explain...kind of a hands on thing...) hope this helps a little..let me know if i can further assist..if I have at all... and ..all machines are different..lol...so the parts that i explained may not even be present...so much for uniformity!!!...lol...thanks for listening...Todd
Nov 23, 2010 | Garden
2001 Hyundai - reverse gear is inoperative. The
If I understand you correctly, you have ALL forward gears working, but reverse doesn't?... then the problem is in the transmission itself or the linkage on the trans linkage into reverse.
Oct 18, 2009 | Hyundai Accent Cars & Trucks
Garden Logo
732 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
