Question about Hyundai 2008 Sonata GLS
How do I install the manual non quick connect version of a 4 pole wiring harness for a trailer on a 2008 Hyundai Sonata gls please? I've got the taps or can soldier them in.
Trying to avoid using the quick connect if possible, I'm comfortable going in and doing the work, that's not terribly hard, just need to know which for what please.
  • 372 Answers
First, if it has seperate turn signals from brakes. You will need a converter if you contact hyundia they may have a setup that plugs in without cutting or splicing
Posted on Apr 11, 2015
  • 54 Answers
SOURCE: change spark plugs 2001 4 cyl hyundai sonata
You change One spark plug, and One wire at a time. Do you know where your timing belt is? If not, its on either the right or left side of the engine. There is a covor to the timing belt. You take the First plug that is closest to that belt. Then you work your way to the next closest all the way to the last one. Remember, you have to do ONE at a time.
Posted on Nov 30, 2008
  • 8 Answers
SOURCE: Where is the engine number of the 2008 hyundai sonata located?
did you check the front passenger door. the no. on my Hyundai Matrix is located inside the f ron passenger door right on the top right corner. its worth a try
Posted on Jan 03, 2009
  • 94 Answers
SOURCE: fuse 10 on hyundai sonata gls cant find schematic for fuse wiring
Register for free at www.hmaservice.com and the information you need can be found in the ETM section.
Posted on Jul 03, 2009
emissionwiz
  • 75814 Answers
SOURCE: Im trying to connect my pioneer radio to my
Radio Constant Wire 12V+: Red
Radio Ignition Switched Wire 12V+: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Pink/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Factory Amplifier Turn On Wire: n/a
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Black
Right Front Speaker Wire (-): Yellow
Left Rear Speaker Wire (+): Blue
Left Rear Speaker Wire (-): Red
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Orange
Posted on Oct 06, 2009
SOURCE: MSD for Hyundai Sonata GLS 1992 16V DOHC
Hi;I live in Iran and I have a Hyundai Sonata GLS 1993 4cyls 1997cc 16V DOHC(G4CP Engine type) and I want to install an ecu 39110-33150 for care
Posted on Aug 17, 2011
Why won't it start?
Hyundai Sonata Questions - My Hyundai Sonata won't start ...
www.cargurus.com > Questions > Hyundai > Sonata
CarGurusMar 5, 2013 - My Hyundai Sonata won't start, everything comes on when the key is turned but no ... it is in park and until I jiggle the shift until the light does come on it will not start. Was in ... My 2009 Sonata has been "perfect" with no issues.
2009 Hyundai Sonata turns over but will not start ... - CarGurus
CarGurusJun 16, 2013 - 2009 Hyundai Sonata turns over but will not start, sometimes. - 70000 kms.
Car wont start? - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/nf-2006...sonata/139435-car-wont-start.html
Mar 14, 2012 - 10 posts - ‎4 authors
2009 Hyundai Sonata GLS 2.4L I4 AT - Slate Blue ... If you turn the ignition to on, not start, do you hear a humming coming from the rear? 2010 Not starting. Fuel Pump? Starter?
Apr 1, 2012
Car Won't Start - Break Pedal Hard !
Mar 4, 2011
2007 Sonata Won't Start
Jan 4, 2011
Car Cranks But Will Not Start
Jan 16, 2008
More results from www.hyundai-forums.com
Jan 01, 2016 | 2009 Hyundai Sonata
I want to tap into the reverse tail light wiring for a surge brake solenioid,
We at not living in the 1960's
You tap into any of today's vehicle circuits, your
asking for unknown problems
Have you considered you said a solenoid,& do you
know the current draw on that solenoid
Best design a new circuit using a relay & control it with
the back up switch ,if the can handle the extra current
Need wiring diagrams,some math & ohm's law there
Feb 07, 2013 | 2010 Hyundai Santa Fe
How do I replace the alternator in a 2002 hyundai sonata GLS v6?
For 2002 Hyundai Sonata 2.7L MFI DOHC 6cyl check this procedure...
Alternator - Removal
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    Negative battery cable Radiator mounting bolts, 1.6L only Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator
    Fig. Exploded view of the alternator-XG 300
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
    Negative battery cable Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator
  3. Install or connect the following:
    Alternator and reposition the radiator, if raised Alternator wiring harness connectors Alternator drive belt
  4. Adjust the alternator belt and torque the bolts to the following specifications:
    1. Accent: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 14-20 ft. lbs. (19-28 Nm).
    2. 2.0L and 2.5L Sonata, Elantra and Tiburon: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 105-132 inch lbs. (12-15 Nm).
    3. 2.4L Sonata: Pivot bolt to 26-41 ft. lbs. (34-54 Nm) and the adjustment bolt to 14-18 ft. lbs. (19-25 Nm).
    4. 3.0L Sonata and XG 300: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 11-16 ft. lbs. (15-22 Nm).
  5. Install the radiator mounting bolts, if removed.
  6. Connect the negative battery cable.
Hope helps (remember rated this).
Jun 25, 2010 | Hyundai Motor 2002 Sonata
Feb 26, 2010 | 1992 Hyundai Sonata
06 Sonata Park Light Out-Easy Fix Please
reach in from either under the hood. Turn and pull out harness and bulb, replace and reinstall
May 28, 2009 | 2008 Hyundai Sonata
Towing wires
Here is a Utube video for you for the wire hookups! http://www.wonderhowto.com/how-to/video/how-to-install-a-trailer-wiring-harness-on-a-hyundai-sonata-164439/
May 10, 2009 | 2008 Hyundai Sonata
Fuse 10 on hyundai sonata gls cant find schematic for fuse wiring
Jun 26, 2008 | 2008 Hyundai Sonata
Hyundai 2008 Sonata GLS Logo
Top Hyundai Heating & Cooling Experts
cwradio73
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you a Hyundai Heating and Cooling Expert? Answer questions, earn points and help others
