Question about HP Photosmart C8180 All-in-One InkJet Printer
No power is getting to the touch screen and buttons.
  • Vicki k Gibson
    Vicki k Gibson Apr 15, 2015
    Thanks! everything was connected, however, I found a small cut in the line that goes to the touchscreen. I had to take it all apart to find that, including the scan part of the printer. Anyway, I guess there is no fixing that as finding that connection flat wire won't be easy. I gave up at this point..(OK maybe) and got the Cannon MG 7520. Has high resolution for photos that I want, and it still has a printer for CD/DVD's Go figure..no fax machine in the way either! THANKS so much for input. If you have any idea where to get the flat connection, I will try and still fix my old printer as I want the photo scanner working once I put it all back together again. Getting good at this!LOL Too bad the line got cut somehow...sigh.
    New Friend:
  • 34 Answers
Most likely you left a cable or cable bundle unplugged somewhere. Double check all your cable connections.
Posted on Apr 14, 2015
Testimonial: "Thanks for all the community help! Nice to find someone out there who cares to do that! Good on you buddy! I will check in with U as I set up my new printer, and see if I can still fix my old one. Cheers!"
I have a Samsung tablet 3 that the touch screen is frozen. I see where ppl are saying to turn off power, hold vol. down & power to get in reboot mode. I can't get mine to power off (touch screen froze) &...
Seems like the digitizer isn't working anymore u may wanna get ur tablet examined but to quickly turn off some tablets is to press and hold the power key till it shuts off and not lock the screen
Oct 21, 2014 | Tablets & eReaders
How to restore to factory default
To perform an External Manual Reset of your handset to restore to factory settings, read instructions below and then perform.
  1. Power off the phone, press and hold volume down button, press power button.
  2. Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
  3. Wait for the "triangle ! / Android" screen then go on to step 4
  4. Tap on bottom right corner of the screen (may take a few times). a menu will come up
  5. Tap on "wipe data/factory reset", and tap OK. Another Confirmation screen will come. Tap Yesand OK
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap OK.
  7. Phone will reboot to initial setup MOTOBLUR screen.
Tip: Once you've reset your device, you can use your existing account to sync your contacts back to the phone.
(Steps on Gingerbread 2.3)
Remove and remount the battery and power up
If the phone still does not boot up to the MOTOBLUR screen, then perform the following Factory Reset instructions:
  1. Power off the phone, press and hold the Volume down button and Power buttonsimultaneously while powering up the unit.
  2. Screen will come up with "Fastboot" at the top of the screen, press Volume down key to cycle through choices until you get "Android Recovery", then press Volume up key to boot in this mode
  3. Wait for the "triangle ! / Android" screen then go on to step 4 android_recoveryscrn.png
  4. Press both Volume up and Volume down key simultaneously. A Recovery Menu will come up
  5. Tap on Volume down key until "wipe data/factory reset" is highlighted, and tap Power button. Another Confirmation screen will come. Tap on Volume down key until coming to Yes and tapPower button
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower button
To Perform a Factory Data Reset through settings menu:
  1. From the Home screen, press Menu
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset (Read notes for other options)
  5. Touch Reset Phone
  6. Touch Erase Everything
Oct 20, 2014 | Samsung Cell Phones
Why Screen won't respond to any touch?
Ur touch pad is gone bad get it replaced
Apr 24, 2014 | T-Mobile Prepaid Prism II
Disabled can get in
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
and restore it
Nov 18, 2013 | Apple iPod touch
LG KS20 touch screen not responding corecttly some times.
LG KS20 touch screen SolutionGo to settings menu - Touch celebration - click correctly touch position - u see done.
or" change your PDA ( touch screen )
Dec 15, 2011 | LG KS20 Smartphone
How to unlock touch screen
  • Press the touch screen once or twice to get it to illuminate so that you can see the unlocking option. On some models you might have to press a side button or the power button once to pull up the "Unlock" screen.
  • 2 Touch the "Unlock" or similar button on the touch screen.
  • 3 Type in your password if you've set one for the phone. Some cell phones just require you to press a series of buttons on the touch screen or accompanying keypad to confirm that you want to unlock the phone.
  • 4 Press "Enter" to unlock the cell phone, which allows you to access your messages and menu options.
  • Dec 11, 2010 | Video Cameras
    Touch screen and push buttons are not responseive.
    Make sure the switch on the side that locks the buttons is not switched on. To be safe, switch it on (so that the red shows) then off.
    Oct 11, 2009 | Dell Axim X51v Pocket PC
    Touchscreen not responding.
    There are three levels of fixes, please try them in order:
    1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
    2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
    3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
    Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
    Ipod touch 8 gb. The screen is frozen
    You must attempt to refresh your iPod Touch.
    Hold the Sleep Button and the Home Button at the same time for 10 seconds. The screen turns off, wait for 5 seconds. Then hold the power button again until you see the Apple Logo. Wait for couple of seconds. Then your problem should resolved!
    If this does not work, let me know. :).
    Mar 20, 2009 | Apple iPod touch
    HP Photosmart C8180 All-in-One InkJet Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
