Question about Water Heaters
Radiators hot no hot water. Luke warm for a bit. Then back cold. Setting is past 'eco' just moved in not used to combi but surely this isn't right
    New Friend:
  • 24 Answers
Check the diverter valve. look to see if when hot water turned on the small electrical switch at the end operates. If not then a ned valve or diaphragm
Posted on Apr 13, 2015
I have main combi 24 if you run water slow it is hot but if you turn it up it is luke warm water
see pic;
Notice the red in the 1st picture? That is all hot water. When you have a broken dip tube the cold water is 3/4 of the water heater.
So like in your case, if you run water slower you may get hotter water longer, but if you run at faster rate, hot water short time and then cold.
Check & if needed replace the dip tube. Easy fix
Feb 25, 2015 | Water Water Heaters
Worcester 350 combi boiler on but water cold and radiators cold. Have put pressure up but made no difference. What's wrong with it?
If the inline pump is not working no hot water will flow into your radiators. The pump pushes the water in the lines to create a water flow. Increasing the pressure will not help in this case. I recommend you put the pressure back down as it usually is preset when the boiler is installed. My pump is about three feet back of the boiler on the intake line. If you don't know what you are doing I recommend getting a repair man as you could create more problems by over heating the boiler its self and blowing the electrical parts up.
Feb 06, 2015 | Water Water Heaters
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Replaced diverter valve on worcester 9.24 combi and still only luke warm water
check your expansion vessel is not flat.if so recharge..simple way to check press in valve on vessel if water comes out or little air recharge..if water still in vessel the diaphram in vessel has split so replace vessel?hot water relys on expansion??
Dec 10, 2012 | Water Heaters
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Central heating radiators downstairs take a long time to heat up
Problem is balancing & flow. Turn down the other rads until the inlet [flow] pipe is hot but the outlet [return] is luke warm. The rads have two valves - use the one which has a non-operation cap [just turns without doing anything]. when all the rads are the same temperature the system is said to be balanced and should be left like that using the other valves [with operating cap] to turn them on or off as required
Dec 13, 2009 | Water Heaters
Not continuous hot water and radiators
If it has a distance from the boiler to your use the water in the lines and the lines themselves ahve to warm up before you will get hot water, Let me know more if this dosnt help. Please rate me as high as possible if it does help you understand your trouble.
May 31, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Water Heaters Logo
118 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
