Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Does not turn on
Every so often the clock stays at 11:57 and will not respond to any buttons. I have unplugged it to reset it and after a few tries it works again. Whats going on? How do I fix this?
  • 515 Answers
Re: Does not turn on
This sounds like an internal circuit issue, and nothing you can really do. If everything is set correctly, and it keeps doing this, then you might have a faulty circuit(s). Professional help should be sought at this point.
Posted on Nov 14, 2007
0 characters
3 Points
My Sony Blu Ray was working fine. I bought a used blu Ray it skipped and froze(the BD player was completely unresponsive) I had to unplug it to power it off for awhile. Then I tried watching Netflix and It...
There should be an option in your setup menu to perform a reset. Reset all settings to factory defaults and try it then. This will sometime sfix this problem. If not, then you are looking at a really expensive replacement main board that will cost you more than the unit is worth
Mar 25, 2015 | Sony DVD & Blu-Ray Players
Did you try unplugging the recorder to reset it?
If that does not work, force a reset by holding down both the channel up and down buttons until it responds (about 10 seconds). Then reset the unit.
Nov 23, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
No picture
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Jan 31, 2009 | Yamaha DVD-S540 DVD Player
Se-d1 will not boot
escient music server...light blinking red...
cant turn on system...
tried resetting...nothing
tried turning system off..for a hour or two...nothing..
juse blinks will not respond to anything...
any ideas.
Jun 28, 2008 | Digital Products Escient SE-D1 FireBall...
LG LRM-519 Not responding to anythiing
I had a LRM-519 that would not get past a very dimly lit "hello" on the LED screen. I called tech support and was advised to make sure no disk was in the unit and turn off the power from the unit (not the remote) and unplug it from the wall outlet. While unplugged, hold down the power button for 30 seconds then plug it back in. This didn't work the first time, but after a few tries it worked for me. My unit hadn't worked for nearly 3 months prior to this. Good luck.
Mar 31, 2008 | LG Electronics LRM-519 Digital Media...
HDD locked?
Have you tried resetting the recorder to it's default settings either through the menu or by pressing and holding the power button while unplugging it. After unplugging leave it of for a few minutes and then turn it on again.
Jan 15, 2008 | LG RH266 Recorder
Non responsive dvd600 by Oritron
Can you take led off, see if DVD stuck inside unit? Find the tray release button and manually open the tray and replug. and see if unit respond.
Aug 10, 2007 | Oritron DVD600 DVD Player
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
