Question about Refrigerators
Water not going from inlet valve to ice maker. I can switch plastic connectors and hold push water switch on door front to make the valve open and send water to the ice maker.
The ice maker side of the valve is getting power, but no neutral to complete the circuit. Is this a problem with the main circuit board?
  • 3,289 Answers
Hi Rick,
Typically, the hot side of circuits are switched - neutral is always presented at the load. This is for safety. If hot were always present - any accidental ground (at any time) would either power up the load until removed - or cause direct short if it contacted the always hot terminal. If the hot is present at the solenoid only during times it is needed to fill, then you you could safely connect the neutral from the other solenoid. HOWEVER - since I do not know which fridge you have and can't verify the wiring - you'll have to do some testing on your own before attempting. Have a look at the neutral side of the solenoid and see if you can't locate a break in the wire somewhere - with the fridge unplugged.
Posted on Apr 10, 2015
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
Ice maker dont work
There are several things that can prevent and icemaker from working.
1- Temp in freezer. If the temp in the freezer is higher than 6 degrees the ice makers thermistat will not call for water.
2- Water inlet valve. If the inlet valve is malfunctioning the silinoid may not be opening. Even if you are getting water through the door.
3- Faulty ice maker. If the internal components of the ice maker are no longer functioning it wont make ice.
To test the inlet valve. In the back of the fridge is and access panel near the bottom remove this panel and look at the inlet valve. now you should see 3 hoses. One is usually copper and runs directly from the house water supply. There will be two other hoses from the inlet. One leads into the fridge for the water in door feature. The other is for the icemaker. Switch the two hoses from the ice maker ( water in door and icemaker) than push the water in door feature and see if the water goes into icemaker. If it does not than replace inlet. If does and temp in freezer is below 6 degrees replace icemaker.
If you need further assistance please comment me back.
Jul 30, 2011 | Kenmore 53642 / 53644 Side by Side...
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Jul 19, 2011 | Kenmore Refrigerators
My freezer is not making ice and the water only drips out of the water side
There could be a couple dif problems. If the temp in the freezer is not below 6 degrees the thermistat in the ice maker will not call for water. The selinoid in the water inlet valve for the freezer may be bad. The ice maker itself may be bad.
To test the inlet valve switch the hoses and see if it calls for water when you call for water in the door. To do this you will need a 1/4 inch nut driver. Remove the panel in the back of the fridge on the outside. Push the connector inwards and pull the hose out. Most inlet valves you can do this with. Switch the hoses and push the water through the door button . If you cant do this you have 2 choices. Either call a technician to test the inlet valve or take a gamble and replace and hope this works.
If the inlet valve is good and the freezer temp is below 6 degrees replace the ice maker.
Jun 30, 2011 | Whirlpool 21.7 cu. ft. Side-by-Side...
I recently replaced the evaporator fan motor. Now I have two problems: 1) Ice maker does not dump ice automatically. The water line is clear and fills up the tray. The ice freezes but will not dump the...
Hi and welcome to FixYa, I am Kelly.
You made this statement:
I have to manually make the ice dump. 2) I now have a slight build up of ice under the ice maker where it appears the water from the ice tray is leaking and the inside of the freezer also has a slight build up of frost on the walls.
From my 40 years of experience that statement is telling me that the freezers' evaporator coils are blocked with ice. (i.e frost on the walls) When the coils become blocked or built up with ice everything APPEARS to be working fine but the actual freezer temp is above 17 deg F. An ice maker will not initiate an ice-harvest cycle until the temps are between 14 - 16 Deg F. I.e it is not cold enough to automatically make ice because the ice maker thermostat is not closing at 14 - 16 deg F to start the ice harvest.
So I will pose these questions for you and answer them:
Q? What causes the ice on the walls
A: The unit is not defrosting properly.
Q? What causes a refrigerator to not defrost properly?
A: There are several; reasons that a refrigerator will not automatically defrost
1. The defrost control has failed (Most common failure)
2. The defrost heating element has failed
3. The defrost thermostat has failed
4. A wiring problem in the defrost circuit
Now.... you also made this statement:
You may have a leaking ice tray but it is quite rare. What usually causes an ice build up directly under and ice maker is the inlet water valve leaking / bypassing water when it is supposed to be shut off. An inlet water valve will bypass water when the internal diaphragm fails or debris is blocking the needle seat of the diaphragm. Either way the only remedy is to replace the inlet water valve because the valves are NOT repairable.
Reach inside your freezer and squeeze the rubber tube that fills the ice maker with water. If there is a problem with the inlet water valve the rubber tube starts freezing up with ice. Eventually when the rubber tube is totally frozen the plastic tube on the back of the refrigerator that connects to the rubber tube either leaks or separates from the rubber tube and ports water onto the floor.
If you really want to prove that there is a problem with the inlet water valve turn the ice maker OFF. Remove the plastic tube from the rubber ice maker fill tube (Just pulls out) and place it in a bucket overnight. IF you note water in the bucket the next day then the inlet water valve has for sure failed. Sometimes they LEAK intermittently when the failure first begins so the bucket test may not reveal a leaking inlet water valve. The key here is you said you have water UNDER the ice maker and you suspect a tray leak.
Here is what I recommend you do after the overnight plastic tube in a bucket leakage / bypassing test:
1. Reinstall the plastic tube on to the rubber fill tube.
2. Turn the ice maker ON
3. UNPLUG the refrigerator and so a manual defrost by removing the freezer contents then directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess)
4. Return the unit to normal service
5. Check for ice production 6 - 8 hours after you performed the manual defrost.
If you have automatic ice production you most likely have and automatic defrosting problem... BUT.... there can be a problem with the freezer door / light switch. The door light switch is a 3 contact switch. One contact is a common power wire and the other 2 contacts turn on the light and provide power to the ice maker (and some times the evaporator fan also depending on unit design)
Test the door light switch amd make sure the light will go off when the door is closed. (depress the plunger) If the light stays on the door switch is bad.
Hopefully you have enough information to understand what is happening with your refrigerator and what the causes of the symptoms you have are.
I think in the end you will have to repair the automatic defrost problem and replace the inlet water valve. Do not forget about testing the door light switch.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | GE Refrigerators
I have a Maytag side by side refrigerator model PSD2450GRW. The ice maker will not make ice but the water comes out front just fine. The freezer works and the ice maker is at the ON position. Thanks for...
Hi and welcome to FixYa, I am Kelly. Usually when an ice maker slows or stops ice production it is a symptom of an aitomatic defrosting problem. The freezer must maintain 14 - 16 Deg F for the ice maker to make ice. Any temp above that an ice production stops. If the freezer is in the 14 - 16 deg F temp range then the problem can be the thermostat in the ice maker or the inlet water valve.
Here is simple test you can do at home to see if the inlet water valve is working:
1. Unlpug the unit for at least 10 minutes.
2. Remove the fiber board cover on the back of the unit.
3. Locate the inlet water valve and SWITCH the 2 connectors on the inler water valve.
4. Open the freezer door and hold the light switch button depressed. (or tape it down)
5. Take a glass and attempt to draw water through the door. Do this just long enout to realize water is going into the ice-maker.
^- NOTE the water will actually be going into the icemaker and the water valve is good!
If you have water going into the ice maker when you try water in door then the problem is either an automatic defrosting problem or an ice maker problem.
MAKE SURE TO RESTORE THE INLET WATER VALVE CONNECTORS to their original positons!
The ice maker can be tested using this link:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
If the icemaker checks out good then the freezer is too warm and there is some reasonthat the freezer is warming up. Usually this is caused one of the following:
1. Defrost control board. Item 13 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48135&diagram_id=28489467#d28489467
2. The defrost element and thermostat. Item 12 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48135&diagram_id=28489469#d28489469
The wiring diagram can be found here:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28489477&pkw_=basket&model_id=48135&NewWindow=1
Here is how I would approch troubleshooting on your unit:
1. Check out the icemaker using the american appliance link above.
2. Do a manual defrost by unplugging the unit and placeing a fan blowing into the freezer compartment for just over 2 hours. (Makes a water mess!)
3. Return the unit to normal service for a few days.
If it starts making ice..... you have an automatic defrost problem or... the evaporator fan is not running at full speed.
One last note... anytime you unplug the unit you must wait about 15 minutes for the cooling system to stabilze or the compressor will NOT start.
Kelly
Jan 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
Kitchen aid KSRG25FKSS05 water and ice maker have stopped working. I have tried numerous things. How should I fix this?
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jan 07, 2011 | Refrigerators
I have model 106.56582500 w/ice maker.water will
HI. First, you will need to rule out any standard issues that will cause this. Check the internal, and external feed lines for any obstructions. Make sure that the internal lines are not frozen, or kinked. If the lines check out ok, move on to the water filter(if equipped).
In most units, there will be a filter, present. These devices are set to operate on a particular time frame. If their filtering limit is met, the filter will stop filtering water, thus, not allowing the fluid to flow, at all. Make sure that the filter is up to date. If you have verified that the filter is ok, move on to the water inlet valve assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to Remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. the multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Now. If the inlet valve is operational, and it has passed the above inspection, this will lead to a faulty inlet switch. This will be located, and mounted on the ice maker module board. First you must make sure of the design. Most ice maker control sectors are the module type and some are the traditional type. the traditional type is refereed to as a component ice maker. These are easier to work on. They have the gear components exposed, just behind the face plate. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. These are not serviceable. You will need to replace the entire module, if this is your type. The inlet switch is not accessible. The ejector motor, and mold heater are the only components that can be tested on a module style ice maker.
To determine which model you have, Remove the outer face plate. If there is a knob, pull it off first, then pry off the face plate with a small screwdriver. If it is a component style ice maker, follow the procedure below to test the inlet switch. if it is a module type, simply replace the entire ice maker. it is not repairable, due to the fact that the inlet switch is not accessible.
component ice maker inlet inspection procedure:(unplug the unit before attempting this inspection)
First you will need to Remove the entire ice maker form the unit.The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, Remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so already. Just along the the edge, nearest the shutoff arm, a pin protrudes through the mounting plate. The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker structure.
the inlet switch is located on the mounting plate, near the cam. the inlet switch is mounted on a thin plastic insulator and can be differentiated from the holding switch which sits on a thick spacer. the inlet switch also uses only two wires, while the holding switch uses three. Remove the switch by removing the two screws that hold it in place. The switch is connected by two wires. Label the wire placement on the switch before disconnecting the wires. The wires are connected to the switch with slip-on connectors.Firmly pull the connectors off of the switch terminals NOTE_ If the connectors are corroded, try to clean them. if the connectors cant be cleaned, simply, replace them.
Now, it is time for the testing section of the procedure.Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Touch one probe to the side terminal and the second probe to each of the other terminals. The reading should be zero on one terminal and infinite on the other. Now, repeat the test while depressing the switch, the readings should now be the reversed. If the switch fails the test, it should be replaced.
* NOTE_ If you have the component type, i would verify motor functions, as well. Test the motor for continuity using a multimeter. Set the multimeter to the ohms setting X10. Touch one probe to the wire from the wire cap. Touch the other probe to each of the two other wires in turn. The reading should be between infinity and zero for each wire.If the motor test results in a zero or infinity reading on either wire, the motor should be replaced.
Jan 05, 2010 | Kenmore Refrigerators
The water dispenser is working fine, but there is not water going to the ice maker. The ice maker is turned on. I have removed the filter and put in the bypass plug. Any suggestions?
Switch the conectors going to the inlet valve.  Then open the freezer door, hold the switch to make the freezer think its closed and push the water button.  If water comes out by the ice maker then the valve is good and your ice maker needs to be replaced. If no water comes out the inlet valve needs to be replaced
Oct 25, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Frigidair frs22zrf side by side w/ front ice and water
From what you are describing, it sounds like you need a valve. Another common thing I run into is the cooling tank inside the fridge freezing. This will usually affect water through the door only. Remove the crispers and you should see a large coil of plastic water line attached to the back wall of fridge. You can check to see if it is frozen by blowing through it from the end of the line you removed from valve. BEWARE, if you blow through it, water will come out dispenser if line is not frozen. Have a towel at front of fridge.
Oct 03, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
