How Do I Get This Off To Replace The Delivery roller?
    Guru:
  • 62 Answers
That C clamp needs to come off(in the picture you'd slide it off towards the right), then that black gear will slide off of the shaft. be careful...those things are known to shoot across the room.
Copier Collin Houston TX Copier and Imaging Expert
Posted on Apr 10, 2015
PAPER GETTING STUCK BEFOR THE OUT TRAY
hi,
paper passing rollers have dirty. clean the small (rubber, Nylon) rollers on the delivery section. ok
or one sensor hold in (yellow foamed) plate middle of the delivery unit. clean it.
best of luck
Aug 13, 2010 | Canon imageRUNNER 400S Copier
The rear roller appears to be making noise as if bearings are going bad. Is there anything to replace or grease?????
Pretty much the bearings have flatten if you are getting a clunking sound these are normally sealed bearings and it is better to replace the roller. Call Icon Fitness @ 1-800-999-3756
Apr 09, 2010 | Reebok 8700 ES Treadmill - Silver Service...
How do you replace Face Down Delivery Roller?
remove the left, back and top covers.
At both ends of the shaft are plastic bushings.
Rotate them so they point in a horizontal position.
Lift the right side of the shaft(it has a white gear on the end) and then slide the shaft to the right to release the left side from the chassis.
Feb 02, 2010 | HP Laser Jet Printer P3005dn
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
My ML2010 printer turns on, takes paper, but stops halfway (blank
Hello sir; Replace paper pick up roller and feed roller.
Aug 02, 2009 | Office Equipment & Supplies
Top roller stripped off rubber when had a jam
If you have just taken delivery, it must still be under waranty. The roller can get stripped so soon. Shld return it to supplier.
May 23, 2009 | Xerox DocuColor 12 Printer
Ir 2000 system Error E 577 what can I do ?
The return roller does not reach home position when the delivery motor
(M1) is driven for a specific time. (If the same condition is detected while
alignment takes place in the direction of feed, a jam will be identified.)
Possible cause The delivery motor (M1) on the finisher controller PCB is faulty. The return
roller home position sensor (S3) is faulty. The connector is discontented
or has an open circuit. The delivery motor relay harness is faulty.
The return roller is faulty. The finisher controller PCB is faulty.
Dec 09, 2008 | Canon imageRUNNER 2000 Copier
Jam in fixing delivery output
try to check the delivery roller there's a small roller will lost.
Jan 22, 2008 | HP LaserJet 3030 All-In-One Printer
k24674
