Question about Juki TL2000Qi Sewing & Quilting Machine TL-2000Qi, 6x9" Arm Space, Extension Table, Drop Feed, Knee Lever 1/2" Foot Lift, Walking Foot, 6 Feet TL98Q
Needle does pick up bobbin thread and auto threader won't thread needle
  • 14 Answers
SOURCE: Juki TL-98QE thread comes out of needle, won't pull up bobbin
It can be many things but first make sure the needle is in correctly, follow the manual to be sure, if it still does not pick up the bobbin thread you may want to bring it to a repairman to see if it is out of timing.
Posted on Jul 07, 2009
  • 55 Answers
SOURCE: needle won't pick up bobbin thread tried cleaning
did you clean the bottom bobbin area thoroughly? Remove the cover plate and bobbin reel, look for debris. Any left over cotton will cause problems, after you clean it spray some wd-40 on all moving parts.
Thanks
Adam
please leave me some feedback
Posted on Feb 18, 2011
SOURCE: My juki hzl35z will not pick up the bobbin thread suddenly! Help!
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Posted on Apr 26, 2012
  • 1564 Answers
SOURCE: Juki, DNU-1541S: thread was not picking up the bobbin thread. The hook shaft is not moving... After trying to move the needle in a reverse motion... Now the hand wheel will not move it is frozen in pl
You've got something binding in the bobbin area. Open up the entire bobbin/feed dog area plates so you can really see. Get your magnifying glass out and really examine the area for threads wound around things. DO NOT unscrew anything if you can help it. If you unscrew the wrong thing you can knock it completely out of time. (which may be why couldn't get the bobbin thread up anyway.)
If all this is intimidating to you... take it for repair.
Posted on Sep 13, 2012
SOURCE: juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Posted on Sep 26, 2012
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
Automatic needle threader stuck
You may have a thread stuck in your bobbin area. Remove your bobbin, brush gently with a clean soft brush to remove dust and/or thread bits, then gently wiggle your hand wheel back and forth, and brush again. This should free up your machine.
Jul 09, 2014 | Janome Sewist 500 Sewing Machine
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Dec 13, 2012 | SINGER 7470 Sewing Machine
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
When I try to sew my bobbin thread is not picked up.
try a new needle failing that you may need to retime the machine
Aug 10, 2011 | Kenmore Sewing Machines
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
Dec 03, 2010 | Elna 2007 Mechanical Sewing Machine
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
Singer 7422
Make sure you have the machine threaded for the bobbin and not threaded through the sewing path. Also, check to make sure that the bobbin is pushed directly against the post as far as possible.
Apr 13, 2008 | Singer 7422
Juki TL2000Qi Sewing & Quilting Machine TL-2000Qi, 6x9" Arm Space, Extension Table, Drop Feed, Knee Lever 1/2" Foot Lift, Walking Foot, 6 Feet TL98Q Logo
537 people viewed this question
Top Juki Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Juki Furniture Expert? Answer questions, earn points and help others
