Question about Kitchen Ranges
Stove about 4 years old started blowing fuse in house main box. Replaced fuses worked 24 hours now it blew again stove was not in use at the time. When it blew 2nd time the fuses were extremly hot.
The house was built in the 40s and we have been here about 21 years with no problems
  • 3,287 Answers
This indicates that one of the heating elements or control has developed a problem. Can you provide the make and model for this range?? Replace the fuses if blown. Check to see if any element is hot - including those inside the stove. Note any that are. Shut off the stove and unplug it from the outlet. When cold, perform a careful visual inspection of the heating elements on the cooktop AND both the bake and broil elements inside the oven (especially any that were found to be hot earlier). Run your fingers along the blind side of the elements to detect any openings, blobs, etc. in the metal covering of the element. Replace any damaged elements with new. Start the process over again - especially the new element. If found hot - check the control - is it on? The control may need replacement, too. This may require more skills / tools than you have and need a pro. Good luck!
Posted on Apr 10, 2015
Panasonic TH37PX80B tv won t turn on
Probable power supply failure.
Apr 02, 2014 | Televison & Video
1991 Miata Help! Won't start, nothing at all on key turn, STILL after battery replacement. Help!
The main fuse blew. Look in your fuse box for a big fuse it should be labeled main or master fuse. Replace this fuse and vehicle should work everything but maybe the starting issues. You have a short somewhere. If the fuse blows again or the car won't start repost the problem
Oct 18, 2017 | Mazda MX-5 Miata Cars & Trucks
Electric stove fuse keeps blowing
more than likely the terminal block where the element actually plugs in has been shorted or damaged and every time you start that particular element it trips the breaker. This is a real easy fix, just take your time and you'll be just fine
Jun 19, 2012 | Kenmore Kitchen Ranges
We have a King Pellet Stove 1 year old. Fuses keep blowing. Have replaced ignitor and fuses several time. Is a surge protector the answer or is it the circuit board? Thanks!
Please understand the reason for fuses blown:
1. High amphs of the main part in the unit. 2. Short circuit 3. Loose wiring. 3. Wire contacts corroded due to rusted or dusty.
Dec 12, 2010 | Heating & Cooling
Harman P68 pellet stove glass fuse blows after 1 minute.
You can do some troubleshooting by looking at the glass fuse after it has failed. If the element looks melted and there is no other discoloration, then the fuse probably blew as a result of an overload somewhere. If the fuse is burned black, then it's probably a short in the system.
You can meter the motors to see if they are shorted anywhere or open.
It sounds like you may be correct about the circuit board.
Jan 02, 2010 | Kitchen Appliances - Others
Circuit breaker popping when stove top/ oven is on
thats how fires start when fuses keep blowing. Just use one at a time. Its probably over loading the fuse you may need a bigger fuse block. Call a local handy man if you havent already
Jan 03, 2009 | Kitchen Ranges
F2e0 error on stove
"cycle the circuit breakers" is to turn the switch for the stove at the electric switch box at the main feed of the house electric panel. This is equivalent to unplugging the stove and plugging it back in.
In the old days, a circuit breaker was a "fuse" in the "fuse box"...
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
