Not printing black what is the fault? - Office Equipment & Supplies
    Guru:
  • 62 Answers
SLOW PRINTER
You have a cartridge problem.
This condition is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
May 03, 2012 | HP Office Equipment & Supplies
My printer print black papers what is the problem
When you give a test print from the menu, you getting the paper with black paper. It could have been the printer power supply earthing problem, Toner ground missing, if the scanner (laser printer scanner) door not opening. Else check the scanner for the fault.
Feb 16, 2012 | Brother MFC-8860DN All-In-One Laser...
My hp laserjet printer print a black page at one side of the paper and the other part its clean..what cause the problem
Depending on what model of printer it is this can be a couple of causes. However they are more often than not caused by a fault somewhere in the cartridge.
The most common cause is a Drum fault in the cartridge. This particular fault is where the Drum has been exposed to Ultraviolet light. If the cartridge is at fault you can prove this by putting in another cartridge and trying again. This can be an empty cartridge as all you are trying to prove is that the cartridge is faulty. It could also be a stripped drum where the coating on the drum has worn or been scraped free from one side of the drum.
Other causes can be a faulty Wiper Blade (Also in the cartridge) this would normally show as a grey panel on the printout rather than solid Black. Faulty PCR also grey rather than solid black.
If it is printing completely blank on one half of the page but completely black on the other when trying to print a solid black page then I would suggest that you have toner settled on one end of the cartridge. Give the cartridge a shake if this is the case to free up the toner.
Jul 06, 2011 | Office Equipment & Supplies
Black ink printing
black developer rollers need replacing.common fault.
Aug 06, 2009 | Samsung CLX 3160fn All-In-One Printer
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
Wonky colour printing!!
you need to run a print alignment test.. this should correct the colour faults (unless you really do have blocked cartridges,
Sep 27, 2007 | HP DeskJet 5550 InkJet Printer
System Fault
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Jan 29, 2007 | Xerox DocuColor 12 Printer
jasbo
jasbo
