Question about Minka Aire Ceiling Fan
Where can you get the transformer/capacitor? Something is humming loud.
The gizmo leaked a brown goo. Its reversable and has three speeds.
    Genius:
  • Minka Master
  • 1,617 Answers
Call Minka @ 1-800-307-3267
Posted on Apr 13, 2015
  • 4 Answers
I had good luck finding replacement fan capacitors for a reasonable price on http://www.newark.com. Match the capacitance in microfarads (uF or MFD) and match a working voltage greater or equal to the capacitor you are replacing. Many fan capacitors are dual units having 3 wires and two capacitance values. You will need to match both values, e.g. "3/1.5 MFD". If you match within 0.5 uF of the original value, it should work fine. Search on Newark's web site for "ceiling fan capacitors". They are about $8 a piece.
Posted on Apr 18, 2015
Have GE built in microwave on top, oven on bottom. Microwave stopped all sudden, changed out fuse and comes back on but soon as press start button..fuse blows and unit stops..need help troubleshoot
If the unit shorts when you push start. it is something shorted in the high voltage section of the unit. The HV section is made up of 4 parts. The High voltage transformer, the Capacitor , the rectifier / diode. and the magnetron. If the mag shorts it will just hum loudly and not heat, so Your problem is probably the capacitor or a shorted transformer. More commonly it is a bad capacitor. If you have an ohm meter, check the capacitor. It should not read shorted. If it does that is your problem. If so replace the rectifier too just for good measure.
Sep 23, 2017 | GE Microwave Ovens
I have a Mackie 406m powered mixer. I was in a club with less than adequate power. My mixer got very hot and started smelling. Now when I turn it on, over 6 months later, it still smells and it has a loud...
More in likely a voltage drop in the club, and the mixers power transformer was fighting for power, so it's brunt or burning up, also there are capacitors that filter the AC transformer hum, they Probably need to be replaced, this can be fixed tho, parts and labor might not be cheap...
Mar 05, 2015 | Mackie Music
Loud hum in my ge rc7200
More than likely the Magnetron is bad, causing the transformer to over heat. Or it could just be the transformer going bad. Either way not a good situation. Both are expensive.
Dec 13, 2014 | GE Microwave Ovens
My JES636WK01 microwave heats up but it makes a loud humming noise. I suspected the Magnetron and disconnected it. The microwave was then operated and the n oiuse was the same. Do you have any ideas
Disconnect the HV transformer leads from the magnetron and the capacitor. Make sure none of the wires are touching the chasis or other parts. If the loud humming sound is still present, it is the High Voltage transformer making the noise. If the noise goes away, it is the High Voltage Capacitor going bad.
*MAKE SURE TO UNPLUG UNIT BEFORE TOUCHING ANY OF THE HIGH VOLTAGE LEADS! ALSO, DISCHARGE THE CAPACITOR BY SHORTING THE TWO SIDES AGAINST EACH OTHER!
Apr 15, 2011 | General Electric Microwave Oven
Amana microwave M#rcs10mpsa that had a loud hum that sounds like it was coming from the transformer or capacitor and then it blows the two control fuses. i replaced the magnatron but it is doing the same...
you need a meter than has the ability to check capacitors. These meters are generally more expensive like 150 bucks and mostly sold for HVAC techs. You disconnect all wires to the cap and connect your test leads. The hum is usually the transformer getting ready to die. Just keep using it until so. The transformer will run you about 130 bucks I think.
Oct 14, 2010 | Amana RFS12MPS Microwave Oven
Loud noise and not heating up
if its making a loud humming noise you need to remove the outer and carefully discharge the high-voltage capacitor in the magnetron circuitry(caps are usually oval in shape and 3 to 5 inches long) after this disconnect one terminal of the cap and check it for being open,then do the same on the high-voltage diode and check this for front to back resistance high in one direction and lower with the meters leads reversed on the diode,the humming is coming from the transformer not being loaded by the cap and diode to double the voltage required by the magnetron tube of -2,000 volts D.C.
Apr 26, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Adcom GFA 5500 'mechanical' hum from amplifier
Possibly. Most amps filter out line hum via low-pass filters. If you can locate a schematic, those would be the caps to check.
Apr 24, 2010 | Adcom GFA-5802 2-Channel Amplifier
The screen will suddenly begin flashing on and off for long periods of times.
the inverter board has an issue, take the monitor apart and see if there a Capacitor that is bulged or leaking a brown goo from it, if there is a blown capacitor then replace them with same type and heat rating. after than put the monitor back together.
hope this solves the problem.
PS the inverter board is the Board with the big transformer on it its normally the yellow/brown colored board.
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Feb 19, 2010 | ViewSonic VX910 19" LCD Monitor
Loud humming
Ouch. Magnetron check performed with multi meter.
1) Disconnect power to unit
2)Allow to stand for minimum 5minutes
3)Remove cover
4)Find large insulted screwdriver
5)short terminals of capacitor to dissapate charge. (If no pop or crackle its possbly already bled through resistor.
Right. Magnetron check both terminals for short to casing if shorted, replace. Check reading between terminals low resistance or direct short is not a problem. Open circuit, replace.
For non heating, this is usually barrel fuse, typically HV 5Kv or more, faults in an overcurrent situation.
Check the capacitor for shorts to casing, a short will indicate a failure. Check the diode in the capactior if fitted by reverese continuity check accross the terminals. MUST DISCHARGE FIRST, else you'll blow the meter up and likely recieve a SEVERE burn.
The most common cause would have to be a problem with the capacitor next the transformer for loud humming. Three basic checks for the transformer.
Probe the low voltage side first, open circuit? replace. a low reading is normal, high voltage side is a two part process, take a reading between the two terminals one goes to the magnetron the second to the capacitor directly. this should be approx the same reading as the LV coil. The last and most important coil is to check the coil side ofthe barrel fuse to ground, this will measure between 80 - 150 on a digital meter, around 90 to 100 for a 900w is in the normal range.
Loud humming is created primarily by having a working transformer with no wher to send the voltage out.
It will only be one or more of these three items, which will cause this, the rest is safety and control gear.
Jun 14, 2008 | GE JVM1630 Microwave Oven
Minka Aire Ceiling Fan Logo
464 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
