WHAT CAUSES PRINTER NOT TO PRINT BLACK? - Office Equipment & Supplies
  • 33 Answers
Could be in your printer settings or your black ink needs to be replaced.
Posted on Apr 10, 2015
Why is my dcp135c printing images in brown instead of black
Several probable causes of this.
  1. Your Black is empty and the printer is trying to approximate the Black using the other colours. Check and replace Black.
  2. Your Black printhead is blocked and all you are seeing is the other colours that are used to make the black into a full black. Check cartridge and do a printhead clean to see if this clears it. Also print off a print quality test sheet (In the Ink Management options on the printer)
  3. Another colour has been put into the Black Slot on your printer. Replace the incorrect cartridge and hope that the printhead has not been damaged by using the wrong cartridge. May need several printhead cleans to clear incorrect ink from the feed lines.
Hope this helps.
Oct 07, 2014 | Brother DCP-135C Flatbed Digital MFC...
Hp Photosmart 6510 Black ink will not print
It is a known defect among many PhotoSmart printers, including the 6510. The black ink was programmed to fail at between 50 to 60 black print cartridges. One HP whistleblower said a bug in this programmed failure causes the black ink to suddenly stop printing after 5 to 6 black ink changes instead. When you call in, they offer to sell you a new printer! The service guy I spoke with was extremely nervous. I refused to buy a new printer, given I had put less than a ream of paper through mine. I was on hold for about 10 minutes, then told there was no supervisor, but given an email address to write to. Three weeks later, still no response. Yes, a class action lawsuit needs to happen, not just for the printer malfunction, but for the hours I soent trying to fix it, and new cartridges I bought, thinking I had bad ones.
Jan 27, 2013 | Office Equipment & Supplies
SLOW PRINTER
You have a cartridge problem.
This condition is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
May 03, 2012 | HP Office Equipment & Supplies
HP Office jet printer slow
I think it's that black cartridge!
The problem you've described is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
Assuming the cartridges are original HP (not re-manufactured or refilled) you can check the warranty status by CLICKING HERE
Let me know how you make out.
Ben
May 03, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Kodak esp 3 printer wont print black data. Just changed the ink, both black and color. do I need a new print head or holder? from what I have been reading, there are lots of folks with this problem.
There are various tips for solving the printer problems in Microsoft Office 2010. These problems with the printer may occur due to corrupted drivers installed for printing. Compatibility may be one of the causes. So, users may have to fix the problems by replacing the drivers. Also, remove all the malware infections.
Mar 24, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hi. My printer says "Black print only" which I
Issues with the cartridge are other causes for trouble in your printer. If you have not used your printer for a pretty long time, there's chance for the ink in the cartridge to get solidified, ending up in its damage. The issue could also be caused due to the lack of ink in the cartridges. In order to resolve the issue, you might ensure that you are not keeping your printer idle for very long periods. You could also check its ink level.
Jan 19, 2011 | Brother MFC-290C Printer
Black pages
Take a look here at the possible causes
http://www.printertechs.com/tech/print-defects/blackpages.php
Hope this helps
Remember to vote
good luck
Dec 03, 2008 | Brother HL 1440 Laser Printer
Does not print black
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
Aug 08, 2008 | HP DeskJet 825c InkJet Printer
Black and magenta do not print
talk to your vendor.your printer might be in waranty
Apr 03, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Cannot print in black only
It is not wise to leave the cartridges empty, causes permanent print-head damage on the empty color area. However, if you want to use the other color, say "black", bypassing the cartridge check is simply resetting the counter of the printer... download the utility file "sscserve.exe" you can search it on the internet. Install it then choose your printer on its list box, then by right-clicking on the printer icon of the utility at the bottom right of your window... you should be able to see what you need. Happy printing!!!
Oct 23, 2007 | Epson Stylus Photo R220 InkJet Printer
32 people viewed this question
k24674
