Question about Health & Beauty
What does it mean when a digital scale only reads HHH ?
Mega weight
SOURCE: Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Posted on Nov 20, 2008
ptooshar
  • 19 Answers
SOURCE: scale appears to be inaccurate
this type of less resoluted scale hasn't repeatability. if you wish to repair it, change the loadcell. use 2 x scale capacity of load cell.
Posted on Dec 02, 2008
ptooshar
  • 19 Answers
SOURCE: Weight Display
it is simply zebra no-connection problem, kindly open lcd display unit, after opening you see a small rubber fixed between lcd and printed circuit board (pcb),  reinstall and fit all screws related with lcd and pcb. turn on the scale. you can found ok.
Posted on Dec 03, 2008
ButtFuzz
  • 463 Answers
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Posted on Mar 16, 2009
SOURCE: I have lost my instructions
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Posted on Jun 21, 2009
My digiweigh scale reads 0 - LD what's that mean
Hi Douglas 0-LD means your digiweigh scales are in pounds, 0 means no weight and LD means pounds..... The link below shows how to convert LD to KGS (pounds to kilos)
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Mar 26, 2016 | DigiWeigh Measuring Tools & Sensors
How do I fix a manlloro digital pocket scale when it reads HHH?
I thinkn there is a reset button to press with no weight on the scale if I remember correctly. Might have to calibrate with the test weight too if the calibration is messed up (not likely though).
Jan 03, 2015 | Health & Beauty
Sw13 scale reads HHH
Most likely HHH represents an error message telling you the weight of them item is higher than the scale can handle. For example if you had a very sensitive scale that weighed up to 50 carats and you put a 250 carats ring on the scale, it would give you an over load error message.
May 17, 2014 | NATASHA COLLIS Gold nugget ring with mixed...
Pocket scales read hhh turn
Try this - While it is off, press and hold both the mode and the tare* keys at the same time and press the On/Off key - Release the keys and observe the display - cycle through a series of numbers. Press the mode key once and observe the display "CAL 0" "100.00" then similar numbers as before. This step calibrates
Check here - http://wiki.answers.com/Q/How_do_you_calibrate_digi_weigh_scale_DW-100AX_or_fix_errors_such_as_F--H_or_ERR?#slide=1
Apr 12, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Health O Meter digital scale, model HDR743DQ1-41, reads "EE". What should I do?
The more recent models don't have to be tapped before getting on,if its an older one, the message might mean you took too long or weigh more than the capacity,usually 300,or 330lbs for a digital scale although some go to 400lbs or more. Try switching the battery for a new alkaline or lithium one;digital scales often need more power than a common cell can provide.
Jun 28, 2013 | Health & Beauty
My digiweigh scale reads HHH. What does this mean and how do i fix it?
It worked on mine,
I pushed Mode, Power, Tare at the same time.
It came up in Cal mode.
I added penny's till it was 995 or so then added small pieces paper to it till it was 100 then up popped passed. I turned it off then it works fine now.
Thank You!!!!!!!
Oct 19, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How to calibrate 1000xr us-magnum digital scale
magnum 1000xr pocket scales turns on calibrates goes to different modes but wont show the weight when object placed on the scale,a lock appears in top left of window, is scales broke or do i have to make lock symble dissappear?
May 28, 2011 | Kitchen Appliances - Others
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Digital scale
if scale  shows 0.000 after placing some weight on pan, it means sensor or load cell connection is open, please check sensor connection.
Mar 23, 2008 | Digi 2.5 lb x 0.0002 lb AC/DC Digital...
Health & Beauty Logo
46 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
