Question about netTALK DUO II Voice Over Internet Protocol Telephone Device with 3 Mo
The light on my duo has turned orangr.I have had nettalk for years
What happened to netTalk? HONE WENT OUT AND NO WEBSITE ANYMORE.
Website is there
http://www.nettalk.ca
That said, they do have problems from September 22, 2015
http://www.themiddlemarket.com/news/restructurings/troubled-telecom-business-nettalk-adds-lawsuit-to-list-of-problems-258184-1.html
Nov 20, 2015 | netTALK DUO Wi-Fi VOIP Internet Phone...
How do i cancel nettalk
Log in to your account, click on the "service plans" tab, go to the bottom of the page and click on "remove auto-renew".
Oct 13, 2014 | netTALK DUO II Voice Over Internet...
I got a nettalk duo, it work perfectly but since last friday, i get a ring tone, but i cant dial out, when ppl called me says my number is inactive
Try resetting the box by unplugging the cord next to the green (sometimes red) light it briefly and then return the plug into the box.
Oct 12, 2014 | netTALK DUO2 VOIP Telephone Service
Problems with nettalk
Go to: https://www.nettalkconnect.com/login
Login to your account, click the "Click Chat" under "Logout" (near right top of page) to converse with a CSR to find out the answers to your question.
Jul 22, 2014 | netTALK DUO WI-FI VoIP Gateway
How to do a factory reset on nettalk duo wifi
Look for a button on bottom or side of device. You will need a pin or pointed object to press down and hold for about 2-30 seconds. This will bring it back to factory default settings.
Jun 13, 2014 | NetGear Computers & Internet
My nettalk duo's red light is constantly on .its not working. how can i fix it.
ANSWER : I have had the solid red light come on every so often. I would power cycle the nettalk and it would be find for a while, then go out again. The solution is to assign the nettalk device a STATIC IP that is outside of the range of ip addresses assigned by your router for DHCP.
Example, my linksys e1200 router by default assigns DHCP addresses starting at 192.168.1.100 and goes to 192.168.1.149. If you assign the mac address of the nettalk to an ip outside that range (that is not 192.168.1.1 because that is your router) like 192.168.1.20 it will solve this issue. whenever the nettalk connects to the router, it will always get 192.168.1.20, I think the nettalk can't handle getting different ip addresses from the DHCP server.
Then tTurn off the nettalk, then do a power cycle on your router.
Feb 11, 2012 | NetGear Computers & Internet
I just setup Nettalk Duo and can send and receive calls. But the Answering machine will not work. I have it set for 4 rings and Nettalk voicemail is set for 5 rings. Any suggestions, please help.
Login to your Nettalk account and click on the voicemail tab on the left. Make sure to turn off your voicemail settings for your Nettalk device and save settings. Your answering machine should now pick up after 4 rings.
Mar 11, 2011 | Uniden DECT 6.0 Cordless Phone ID
Have an SBG6580 and purchased a NETTALK DUO (VOIP). Which is trying to connect but can't. Tech support at Nettalk tried to change some settings but it looks like modem is still blocking the port. ...
The only way I got the NETTALK DUO to work keeping my SBG6580 is to use it in cascading mode with my old Linksys router. When I plugged the DUO into the Linksys it worked great.
Nov 14, 2010 | Motorola Computers & Internet
netTALK DUO II Voice Over Internet Protocol Telephone Device with 3 Mo Logo
248 people viewed this question
Top netTALK Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a netTALK Lands Phone Expert? Answer questions, earn points and help others
