Question about Sony Televison & Video
Sony 32inch led tv double image please help - Sony Televison & Video
  • Vikramsingh Rathore Apr 10, 2015
    Post a picture please of the screen
Slinteriors
  • 8617 Answers
SOURCE: double image
If your model number is the PTH5498 you will need to replace both convergence ICs they are stk 392-040 you can get replacements at the followig link and they will provide fre instalation instructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 11, 2008
Slinteriors
  • 8617 Answers
yes you just need two ICs
Posted on Jul 12, 2008
Ecollier2012
  • 3459 Answers
SOURCE: getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Posted on May 09, 2009
SD Tech
  • 14553 Answers
SOURCE: sony rear projection tv showing double
If you have a CONVERGENCE problem and it will not adjust---the two STK-392-150 Chips this set uses need to both be replaced and the set adjusted with the original remote control.
You can, if you are able to do the repair, buy a pair of chips for less than 14 dollars plus shipping on Ebay.
If you cannot do the repair--shop around your area--most shops are going to charge 300 or more for this kind of repair.
When you consider the cost of the parts--if you can do it or know someone who can--you can save the set and a lot of money--This repair can easily be done right in your home in about 1 hour--I know as I have done hundreds of them---did two today.
The chips (with the back off of the set) should be on two metal heat sinks on the board on the far left---they will be facing the front of the set.
All that is required to get at them is to remove all the plugs on that board and the screws that hold it in and tilt it up so the bottom of the board is in view---you unsolder both chips (about 18 pins each) and remove the 2 screws that hold each to a heat sink.
With 2 new chips you put heat sink compound on the back of each--it is a white grease to move heat quickly from the chip to the metal, and solder both chips in----put the board back down and all the plugs back(I usually mark all of them so I know where they go) and turn the set on and see what you have...
Most of the time this repairs the set--go into the customer menu and adjust the convergence and you are ready for another 5-8 years of life---this is the normal lifespan of these chips.
If you need assistance or have questions let me know--I am here to help people.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Posted on Nov 08, 2009
toolkits
  • 1099 Answers
SOURCE: double vision sony tv
Hello, This is the "kiss of death" for an projection set. It is failure of the convergence electronics. And, it is not something you can do by yourself unless you have technical skills and know how to use a soldering iron at the advanced level.
Posted on May 19, 2010
Good afternoon, how can fix the double image in Sony KLV-32EX330 Please help me to learn to fix my tv, thanks for the answer,
double imaging or ghosting is normally a result of faulty tv antenna,cable or connections
check that the antenna is pointing in the direction of the transmitter or tower 9 change from strong winds etc)
raise it higher from the roof line to prevent signal reflection
ensure that the antenna in use is correct for the station signals
call in an antenna expert to check the antenna and signal strength
Jul 20, 2016 | Sony Televison & Video
Sony led tv double image how to repair plz yell me..
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Search for "double image"
Apr 06, 2016 | Sony Televison & Video
Philips 32inch LCD tv.. when powered on runs fine for 5 mins and then it flicks and double image starts.. What will be the problem???
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 19, 2015 | Philips 32PFL3403D/27 32 in. LCD TV
Can I connect a SamsungSmartTV model VE32H5500 32inch LED to a belkin modemF5D8636 4v2?
You should be able to connect the tv and the router. You may need to avoid to use special characters for wifi password.
Jan 07, 2015 | Belkin (F5D7230-4) Router (587009)
My Sony 32inch is blinking in standby mode and won't turn on
Sorry to tell you this i have the same TV.I have just checked the manual it says TO count how many times the light flashes in 3 second intervals.Then turn the tv off and un plug it from the mains.Sorrry then you will have to ring the Sony service centre and explain the problem.
Aug 17, 2012 | Sony Bravia XBR KDL-32XBR4 32inch LCD HDTV
Tv wont trurn on
Re-check the lamp door alignment. If the door is not installed properly, the interlock switch will open causing a no start condition. Also observe the red LED on the front panel. When you turn on the TV, a gree LED will blink on and off until the image appears. If the image fails to appear the green LED will give way to a red LED that will flash a specific number of times in between pauses. 3 blinks means the door is not installed correctly. 4 blinks means that a fan has stopped working, etc.
michtech
Feb 17, 2009 | Sony KDS-50A2000 50" HDTV
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
112 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
