Question about RCA Audio Players & Recorders
How do I connect the turntable rca connectors to the tv and then find the connection on the source link
  • RCA Master
  • 5,158 Answers
I don't know of any TV that will allow turntables to be directly connected to a TV. The sound from most TV's isn't that good, most people connect the TV to an Hi-Fi Amp for better sound.
TV's for example will not have a magnetic cartridge pre-amp built in. So even if you have right and left audio in jacks on your TV the sound would be far to low to hear it properly.
Posted on Apr 22, 2015
4 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Posted on Jan 11, 2009
  • 104 Answers
SOURCE: I need a grounding wire to connect to my Griffin Imik
not sure I fully follow your question but the 3 rd ground wire from the turntable would hook up to the ground screw on the imic
Posted on Feb 11, 2009
technical114
  • 1851 Answers
SOURCE: I have a vintage german
The problem in cases like these is not the connector (you can connect direct the cables), it's the type of the pick-up cartridge. Those days the cartridges were crystal/ceramic type. This means that I think you will not be able to find a replacement for this cartridge. Since the whole console (including the turntable) is in good condition I suggest you to replace this cartridge with a moving magnet (the last type that used the turntables, just before the moving coil ones) but you will also need a phone preamplifier in order to feed the signal to any line in input of the system. If you like rebuilding the oldies it's a good idea.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution. Please consider leaving a 4-thumbs rating; I'd appreciate it greatly.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Aug 27, 2010
How to connecting magnavox recorder to tv
Pretty simple. You should have a cord with RCA connectors. They are colored Red, White and Yellow. The Red is audio right, the White is audio left and the yellow is video. On the recorder side connect those three to the OUT connectors that will be color coded as well. On the TV side plug them into the IN connectors also color coded. Make a sure to change the TV source to whatever you plug into (ex. Input 1)
Aug 14, 2014 | Televison & Video
Why does the tv have component video when its an analog tv and how do you hook it up
Component video IS analog. It is also known as Y-Pr-Br. These connections are typically RCA connectors colored Red/Green/Blue.
Component will give you the highest quality signal for analog connections (vs Composite Video (yellowRCA) or S-Video(the round 4 pin connector) Of course HDMI will be best if it is supported.
Keep in mind video signal formats are NOT interchangable, you cannot plug a Composite Video into a Component Input
All you need is a component source (typically a DVD player) and 3 RCA cables and match the colors up.
You will also need to connect the Audio connectors (Red/White) with RCA cables, as the Component is Video only
I hope this helps,
Magoo
Mar 11, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Need advice on how to use Advance Digital ADS Instant Music RDX-150
Assuming you have recording software on your machine already: (GoldWave, Audacity...)
Plug the USB cable into the back of the ADS and into the computer
Connect a line-level analog audio source (tape player, turntable, radio, amplifier, etc.) to the ADS using the appropriate cable to fit the source on the one end and has RCA connectors on the other - plug into the Audio In jacks (Red and White)
Ensure that the recording source on the computer is set to the appropriate USB port
Select record in the software and start the analog source playing
Note: If you are using a microphone, make sure it is amplified to line-level before using as a source.
Jan 22, 2011 | Advance Digital ADS Instant Music RDX-150...
What channel for the TV?
The connection to your TV should be with the cable that has three RCA type connectors on one end, 1 yellow, 1 red, and 1 white. These would connect to corresponding labeled connections on the back of your TV. The TV connection would be called something like VIDEO 1 or A/V1. On your remote you should then have a button either labeled the same, or labeled as SOURCE. This would allow you to switch between different connectors until you have the one you actually connected your Wii to.
Mar 16, 2010 | Nintendo Wii Console
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
Nov 22, 2009 | Dell Latitude D600 Notebook
Mono
http://www.radioshack.com/product/index.jsp?productId=2102978
http://www.radioshack.com/product/index.jsp?productId=2102977
What you need is one of each of the RCA Y-adaptors like at the above links. Radio shack probably has non-gold cheaper ones in the store. on the one that is radio shack model #42-2608 hook the two 'female' connectors to your turntable's red n white RCA outputs. then take the radio shack model 42-2609 and hook the two 'male' connectors to your serato. finally connect the two Y-adaptors together in the middle! This merges both channel but keeps them both equally going into your serato so that no actual musical info is lost.
Feb 11, 2009 | Technics SL-1200 Turntable
Jan 21, 2009 | Teac P-A688 Turntable
No sound
Steve make sure that the coax is connected to the output on the DVD/VCR and to the TV's cable or antenna input. This should give you picture and sound on CH 3. If you use RCA jacks you must also use the yellow video plug as well on the same input on the TV as well as on the DVD to get both picture and sound to the tv. The place yoou put the RCA's on the TV will determine where the image will be displayed e.g. if connected to VIDEO 1 on TV YOU MUST CHANGE THE TV TO THE INPUT NAMED AUDIO 1. You can do this by using the input or source button on the remote control for the tv or go into the tv's menu and perform the task that way. I hope this helps you resolve the issue. Thanks for using Fix Ya and let me know if I can be of more assistance.
Oct 15, 2008 | RCA DRC8295N DVD Recorder/VCR
Vcr taping using rca
Connect the VCR's audio/video outputs to the TV's audio/video inputs. These are the red,white,yellow connectors. get the same colored type cables and it is real easy. Switch the TV to the corresponding input selection. Of course, the signal source needs to be connected to the VCR's input
Dec 30, 2007 | Televison & Video
238 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
