Question about General Electric Heating & Cooling
On my wall mount General Electric air condition compressor kicks on makes noise and then turns back off what could be the problem
    Master:
    Sergeant:
  • 388 Answers
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If your problem is still there we would suggest you seek professional help.
AC Repair Coral Springs
Posted on Apr 12, 2015
  • 230 Answers
SOURCE: Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Posted on Jun 10, 2008
22yooper
  • 828 Answers
SOURCE: tempstar air unit won't run,
Your fuses can have continuity and you still may not have high voltage to run the unit. Check your circuit breaker in your main power panel. It should be marked for the A/C .
The term for the cooling coil is Evaporator. The condensing unit is the outside unit and it does not have a drain.
Posted on Jul 11, 2008
  • 189 Answers
SOURCE: squealing and sometimes doesn't blow cool
A squealing noise is most likely the bearings going bad in the blower motor. This will slow the motor down. If the blower is not operating at the proper speed this will affect the temperature pressure relationship of the refrigerant. This will cause the unit to put out the wrong temperature. Running the unit to long under these conditions can possibly cause further problems ( including a very high electric bill). I recommend that use do not use this unit untill it is repaired or replaced.
Good luck.....
Posted on May 03, 2009
Reeferman
  • 6 Answers
SOURCE: compressor not kicking in when i turn the air conditioning on.
what is the make and model? how long has it been switched on? is the compressor top hot?
Posted on Jun 23, 2009
  • 30 Answers
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
Freezer making loud buzzing noise when turned on. We had storm and lost power sounds like its coming from on and off switch
the power grid may not be up to full power
happens after a power up every electric unit left on in the grid
on a storm all kick in in a massive load
turn off at the wall
unplug
plug back in
see if compressor startup again
Oct 15, 2016 | Refrigerators
Tip
How to fix problem of Air conditioner doesn't turn on
If your central air conditioner doesn't go on automatically:
1) Be sure the thermostat is set to “cool” and that the set temperature is well below the ambient temperature.
2) A central air conditioner should be on a dedicated 240-volt circuit; check the main electrical panel and any secondary circuit panels for a tripped breaker or blown fuse. If you find the problem there, reset the breaker or replace the fuse.
3) Make sure the furnace power switch is turned on and that the outdoor condenser's power switch, which is mounted on the outdoor unit, hasn't been shut off. Also, be sure the 240-volt disconnect next to the compressor, which is in a metal box, usually mounted on the house wall, hasn't been shut off.
4) Turn off the power to the air conditioner and check the thermostat.
5) Remove the thermostat's cover and unscrew the wire from the Y terminal.
6) Turn the power back on.
7) Holding the wire by its insulation ONLY, touch the bare end to the R terminal and hold it there for about two minutes. If the compressor kicks on, the thermostat is faulty; replace it or call an air-conditioning technician. If the compressor doesn't go on when you hold the two wires together, turn the power back off and call a technician.
on Sep 02, 2010 | Heating & Cooling
Air conditioning does not blow cold air in my 2004 nissan x terra
If your a/c compressor kicks on and your manifold gauges show proper hi/lo readings then I would inspect the blend door. The blend door is a motor that moves back and forth when u set the temp for hot or cold . In your case, it may be stuck in the same position. The blend door is located in the dash, usually behind the glove box or in that general area. I hope you are able to fix your problem. Scott
Jan 22, 2013 | 2004 Nissan XTerra
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Delonghi PAC AN140HPEC clicking noise.
1) test the mounting pads and bracket for worn
2) The compressor and motor are powerful device for make enough noise.
3) Try to adjust it very well in the frame windows, for vibration.
God bless you
Jun 22, 2012 | Heating & Cooling
AC is not cooling
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device that is called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Carrier 38CKC036 Air Conditioner
Compressor not kicking in when i turn the air conditioning on.
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Squealing and sometimes doesn't blow cool
Good luck.....
May 03, 2009 | Friedrich M18CF Split System Air...
Motor labouring - electric breaker kicking out
The problem that you describe could be casued by several problems that you can check yourself. I usually begin by checking the in-tank check valve for leaking air back to the pump. Follow the air discharge hose to the tank and you will find the brass checkvalve. With about 80psi in the tank, unplug the unit from the wall and loosen the smaller fitting (or larger whichever is easier ) at the checkvalve and listen for air leak. If leaking replace with generic valve available at www.grainger.com. Just pay attention to pipe sizes. If no leaks at check valve, remove capacitors from the motor (mark the leads) and test with meter. Repair shops usually test for free if you do not have a meter that can test capacitors. The caps should test within 95% of rating printed on side. Replace with generic to save money just watch size so that they will fit under cover (also available at grainger). If no problems so far, remove the belt and check bearings on motor and compressor for noise (should be relative silent as your turn it by hand). Worn bearings on the motor will cause the motor to overheat. Worn bearings on compressor will just make noise but usually not cause your problem. If all good, then problem could be valves in pump leaking causing the pump to become very hot. This is a visual inspection by removing the head. Finally the electric motor uses sealed bearings and cannot be lubed, only replaced due to age. Good luck
Mar 24, 2009 | Coleman Air Tools & Compressors
Central air conditioner doesn't turn on... Any suggestions?
If the compressor turns off and won?t come back on during a very hot day, the unit may have built up a high "head" pressure and the high-pressure limit switch may have tripped. This is usually located right inside the access panel on the compressor unit. Simply push the button to return it to operation. If your central air conditioner doesn't go on automatically: 1) Be sure the thermostat is set to "cool" and set below room temperature. 2) A central air conditioner should be on a dedicated 240-volt circuit; check the main electrical panel and any secondary circuit panels for a tripped breaker or blown fuse. If you find the problem here, reset the breaker or replace the fuse. 3) Make sure the furnace power switch is turned on and that the outdoor condenser's power switch, mounted on the outdoor unit, hasn't been shut off. Also be sure the 240-volt disconnect next to the compressor (in a metal box, usually mounted on the house wall) hasn't been shut off. 4) Turn off the power to the air conditioner and check the thermostat. 5) Remove the thermostat's cover and unscrew the wire from the Y terminal. 6) Turn the power back on. 7) Holding the wire by its insulation, touch the bare end to the R terminal and hold it there for about 2 minutes. If the compressor kicks on, the thermostat is faulty; replace it or call an air conditioning technician. If the compressor doesn't go on when you hold the two wires together, turn the power back off and call a service technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
174 people viewed this question
Top General Electric Heating & Cooling Experts
Bill Long
MightyMikeJr
Are you a General Electric Heating and Cooling Expert? Answer questions, earn points and help others
