Question about Dishwashers
Cycle stalled and the unit will not drain - Dishwashers
  • 473 Answers
If this is an electronic control, turn off power/breaker to dishwasher for 5 minutes and then back on. Then try again and see if that resets the control. It should go into a drain cycle when power is first turned back on.
Posted on Apr 10, 2015
Not finishing cycle
Is it draining out the water?? Dishwashers fill, spray, and drain more than several times during a cycle. After starting a cycle, let the unit fill, start spraying, and then cancel the cycle--listen for the drain pump activating and pumping out the water. If water is not being drained properly(within a certain time limit), the unit will error code out and stop. Also, make sure the filter is clear--if it gets clogged with "muck", enough water won't be sprayed onto the dishes properly, the pump will require too much energy to try to pump water, the control will sense this and shut down the unit to protect it.
Jul 25, 2015 | KitchenAid KDHE704DSS 24 6-Cycle/7-Option...
Maytag jetclean eq plus mdb9150awd Stalls at 68 min
Could be defective timer. The diagram might be on the back of the machine - out of sight, out of mind
Jul 24, 2013 | Dishwashers
I have whirlpool du915pwpb0 and accessible broken pieces of dishes have been removed from filer module but now unit won't drain at end of cycle
If it drains during the other stages of the cycle it sounds like there is a faulty control that tells the unit to drain at the end of the cycle. If it is not draining during any of the stages of the wash cycle it may be a faulty pump.
Dec 10, 2012 | Plumbing
Our whirlpool sport will not drain, 5d code has appeared. what can we do
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
• If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water left in tub after wash cycle
Can you hear the water pump running when it is supposed to drain just before the spin cycle? If it doesn't, the pump motor may be bad or the pump itself may have blockage that stalls the motor. If it runs, but doesn't pump anything, look for pinched drain hoses, an internally blocked drain (a stray sock perhaps?) within the outer tub, or a plugged pump/loose impeller. Hope this helps!
Apr 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer stops during rinse cycle
if unit is stoppin in rinse cycle and not advancing into drain/spin mode. you lift the lid and its stalled full of water??? clos the lid again and listen for a slight "clicking" noise, chances are you lid switch has gone bad, and the machine does not recognize the door being closed, and for safety reasons will not drain/ and or spin..very common issue!
Jan 27, 2010 | Kenmore Washing Machines
What does 5d mean?
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters ofwater and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Run a NORMAL cycle without adding any detergent.
8. Verify CCU operation by running a Diagnostic Test or any Cycle.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer stalls out on rinse cycle
This is likely a lid switch problem. They tend to get weak and work sometimes and sometimes not. When it stalls like that try pushing down on lid and see if it kicks in. If so you need to replace the lid switch
May 11, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
Owen Barnes
