Question about Fisher and Paykel Washing Machines
My fisher and paykel top loader washng machine is bloked and will not Rinse, drain and spin. Mainly Drain as im pretty sure its blocked from fluff etc nybody can plese tel me how to unblock it? Thanks
  • Fisher and P... Master
  • 5,323 Answers
The drain water pump is the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
Posted on Apr 13, 2015
SOURCE: RE: won't drain
I had the same symptoms (washes normally, but won't drain/spin) It would only make a faint hum. I found it fairly easy to lift and tilt back the upper section id by removing the front two screws under the lid. The aggitator came out easily by removing the softener cup and unscrewing the large plastic wingnut inside. The upper plastic shroud came off by carefully removing the eight or so plastic tabs. Once the shroud was off, I could lift out the main wash tub. With the wash tub out, I was able to remove all remaining water from the holding tub with a cup and sponge out all water down into the depression where the pump assembly is located. One screw removed the cover to the pump assembly. Once apart, I found a thin piece of plastic was jamming the pump impeller from spinning. I blew through the drain hose from the back to ensure the drain system was clean. Reassembled in reverse in less than 10 minutes. It worked. Thanks Fixya!!!
Posted on Jan 22, 2008
  • 1294 Answers
SOURCE: fisher & Paykel Smart Drive 9 Pride
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum). Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Mar 13, 2008
  • 22 Answers
SOURCE: washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Posted on Oct 21, 2008
SOURCE: Fisher & paykel top load washing machine
We had the same problem with our washing machine being full of water and beeping during the rinse cycle. The problem is that the filter, which is located under the washing machine, is plugged with something. Ours was plugged with a cotton swab. You have to tip the washing machine up and remove the filter and unplug it. The filter is in the center of the bottom of the machine. It twists off. I had to get the cotton swab out of inside the machine through this opening.
This machine plugs up a lot - I've never experience this with any other washing machine. Good Luck!
Posted on Nov 07, 2008
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Jan 27, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Elba washing machine wont drain or spin
The pump filter is blocked ,so it wont empty,remove filter cap and clear out lint, coins etc.
Jan 03, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
My Model GW712 won't spin or drain Top loader fisher & paykel
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
Nov 06, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fischer & Paykel washer will not drain. What do I do?
take clothes out,check the hose for is it blocked or kinked put a clothes hanger in hose and see if you can un-snake any thing out,then put draino-max jel in washer and let it set for about 2-3hrs,see there may be hair blocking the pump were it drains,this stuff work great for front-loader so let it sit.then try putting on drain it may take a few times,the when it drains,run washer on full cycle no clothes hot-water let it go through a full wash cycle etc.
Aug 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Washing machine will not spin or drain
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
May 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
My washing machine wont drain the water
if its making a humming sound the pump may be blocked turn the pump fan by hand to see if its free,
Mar 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
115 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
