If the warning light says "chg oil" the meter is telling you it is time to change the oil. The meter will automatically re-set after 6-8 hours of run time. It cannot be manually re-set.
the timing is set by the magneto sitting on the Shaft that is fixed by a Keyway. If the timing is off it is because you broke the key. Did you hit something that made the mower stop?
you could put some screws threw the wheel into the tire or glue them on with plastic epoxy put there must be a defect in the batch of wheels there getting
the timing is fixed by way of woodruff key in the crank which locates into a chanel in the flywheel and is not adjustable. If you mean the air gap between the ignition unit and flywheel then set it to aprox .002-.005 inch
Recheck the valve lash sometimes they are set too tight. Do a compression test if the valve are set ok. If it indicated lower than 80 psi it may be a burn out valve.
