Question about Air Tools & Compressors
The safety lever is broke I would like to know where to get one Harbor freight cant get one
    New Friend:
  • 131 Answers
No parts for Harbor Freight nailers. Throw away tools.
Posted on Apr 24, 2015
3 Suggested Answers
airnailer
  • 109 Answers
SOURCE: I bought a Harbor Freight 34 degree Nail Gun,
if its oiled, then take all the nails out of the track and chamber, check to see if your firing valve is stuck( it is suppose to go up and down , opening and closeing the cylinder, but sometimes it gets stuck) first press the safety in all the way ( you may have to pull the feeder down ) then press the trigger , then hook the hose to the gun in that order this will sometimes unstick the firing valve
Posted on Feb 16, 2010
  • 1388 Answers
SOURCE: Need a gasket for the
Parts are generally not available for these guns, however you can make a much better gasket (factory gasket was made out of plastic and fails) using material from auto parts store (do not use cork, but paper type). They may not have the right thickness, but using two layers works just fine. Take two layers of gasket material larger than needed (say 6 inch square )and staple them together around edges cut hole in center larger than cylinder and mark exactly where bolts pass thru and vent hole. I use leather punch to punch holes (but any punch will do). Place gasket on body of gun and bolt down head for air pressure test. If test ok you can trim excess gasket with exacto knife without removing head or mark gasket remove head and trim. I usually do not trim too closely as origional gasket on the inside. No need to use gasket sealer. You can even make a temp gasket using cerial box. About three layers of cerial box will work untill moisture enters gun, then over time the cardboard will get soft. Good luck
Posted on Mar 16, 2011
My Harbor Freight pressure washer Portland 1750 wont start
-It's so cheap. That's why.
I'll never buy any power machine from harbor freight.
Good luck
Mai Lor
Sep 11, 2017 | Garden
Where can I get a manual for my quarter inch Rockworth Router Model No. ARPR122T
Harbor Freight Tools 44914 Router User Manual - ManualsOnline.com
powertool.manualsonline.com > ... > Harbor Freight Tools Router
Harbor Freight Tools 44914 Router User Manual. Page 1 ... 1/4 INCH TRIMMERROUTER ... or form without the express written consent of Harbor Freight Tools.Missing: rockworth ‎arpr122t
Jun 02, 2016 | Cars & Trucks
How can I open my Bunker hill safe 95824 with a battery failure ?
Call harbor freight in CA and they'll let you know if there is a cure. They have an 8xx number for ordering parts and such, which is also their 'tech support' line.
Aug 15, 2014 | Computers & Internet
Soldering gun melts tips
180 watts is way too much for a soldering iron unless you are repairing copper pipes or soldering 4 gauge wires. You can't just let that stand, it must be used or it will overheat. Harbor freight is were you buy tools that are meant to be used one time. They are junk - I'm not judging you because I don't know what project you have - it is likely a one-time project.
Jan 24, 2014 | Welding Tools
How do I remove a broken blade on a reciprocating saw? The blade broke off at the place where it attaches to the body. Unlocking the blade by the usual means doesn't free the small piece remaining in...
Sometimes if you take the set screw completely out and then use a flat blade small screw driver to wege open the throat you can use a dental pick to get it out. Spray it first with wd40.
Hope you weren't using those cheap blades from harbor freight - that is how I learned that trick - bought the dental picks from harbor freight.
Jun 20, 2011 | Dewalt DW303 Heavy Duty 65 Amp...
I bought a Harbor Freight 34 degree Nail Gun, model 93099. I shot about two clips of nails, but now when I press the trigger, I get a blast of air. I removed the safety trigger and (carefully) pushed in...
Feb 04, 2010 | Air Tools & Compressors
I own a 16" wood planer and I cranked the wheel down a little to much and it seems like I have broke the shaft on the blade. The name on the planer is central machinery but i cannot seem to find that...
Harbor Freight is the dealer for Central Machinery tools. Take your model number, and look it up on their website. They have all the parts available by mailorder. I have a electric jack hammer and have ordered parts for it, as well as a wet tile saw. Hope this helps.
Nov 02, 2009 | Jet 16" Wood Planer - 708531
My mower wont start it will turn over but wont fire its a murray
You must specify what engine.That helps us know what to tell ya. Now some will turn over but not start because of a bad safety switch which grounds out the coil. Seat switch if the first place to look and then clutch switch. Make sure you use a good spark tester.Harbor Freight has em cheap. It could be a coil problem.
Oct 20, 2009 | Garden
Chrysler 300 2001 hood won't open cable is broke
obtain a very large needlenosed plier and twist the lever as the cable would; if you can go through the grille opening with the plier.
these large 15 inch pliers are sold at Sears & Harbor Freight Tools
Apr 21, 2009 | Chrysler 300 Cars & Trucks
Air Tools & Compressors Logo
476 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
