Question about Capcom Devil May Cry: DMC Definitive Edition PS4 UK IMPORT
The game crashed and now my save is corrupted. Can anything be done?
I got error code CE-34878-0 after starting the game. I restarted and it says my save game is corrupted
Error code CE - 3316 - 4 for The Last of Us Remastered
connection error 3316 u have to reset your ps4 controller . on the back there should be a small hole that u can insert a needle through then reset it then connect it through wire and it should work fine.
Jun 12, 2016 | Sony PlayStation 4
What does error CE-36329-3 indicate on a frozen PS4?
per Sony's site :
Here are a few ways to deal with the error message:
Option 1 (Update system software and application data): Close the application, install the latest system software and game update, and restart the system.
Option 2 (PS Camera Compatibility): If a PS Camera is connected to the system, remove it and reboot the system, then go to [Settings] > [User] > [Login Settings] and turn "Enable Face Recognition" OFF.
Step 3 (Save Data Issues): If the error occurs again, back up your saved data, and then go to [Settings] > [Initialization] and choose [Initialize PS4]. If it continues after initialization, check to see if you have save data in online storage. If you suspect incorrect save data in online storage, remove the affected save from system and online storage.
Things to remember:
  1. Check to see if this error occurs with multiple titles. If not, you may be dealing with a game or app specific crash that may be helped by re-patching/re-downloading.
  2. If you suspect issues due to your local network, try using a wired connection and/or checking your network settings results http://manuals.playstation.net/document/en/ps4/settings/nw_test.html
  3. Periodically back up saves to USB and/or online storage if you have Save Data concerns.
Oct 11, 2015 | Video Game Consoles & Games
How to Fix error code Ce-34878-0 on PS4
If you are experiencing this ce-34878-0 error code, please close the application and then install the latest system software and game patch. If the error occurs again, initialise the PS4 system after back-up of the save data and please also submit any crash reports after re-booting your console when the error occurs. Sure the "solution" isn't exactly helpful for those that have already lost their save file, but it's good to have something to refer to when the error hits. Until Sony patches the PS4 for this error, this is probably as close to a fix as we'll get.
Apr 04, 2014 | Washing Machines
Keeps kicking me from my game
Hi Josh,
Which PS4 title is this for?
Thanks
Ashlee
Dec 12, 2013 | Sony Video Game Consoles & Games
When i click on training it causes a crash dump
here are instruction to fix crash dumo to your sega football manager 2011
Step 1shock.gifpen up your steam
Step 2: Go onto your games list
Step 3: Right click on Football Manager and select properties
Step 4: Select the Local files tab on the far right
Step 5: Click the option Verify integrity of game cache
Step 6: Click the option Defragment game cache
It should now be complete
this worked for me
I'm sure there are other people out there who have had there game destroyed by Crash Dumps errors, sometimes screwing your save, sometimes even preventing you from starting new games forcing you to re-install only to come across the same problem later down the line.
So here is my 2 part guide to Crash Dumps, part 1 is how to set your game up to minimize the chances of your game ever getting this error, and part 2 is what to do to recover your save (If possible) and get your game back to a working state if you had this error already. Part 1 pretty much lists all issues that cause Crash Dumps and to set your self up to prevent it from happening.
Crash Dumps Prevention
There are certain things that increase your chances of getting an error, here is a list
1) FMRTE - Just dont go there, it screws your data base up beyond repair, you will not be able to get your corrupt save back if you have used this editor. Sometimes its been to known to cause damage to your windows registry too, unless SI make an official in game editor, using third party programs like this is all to risky stay away.
2) Size of Game - Even though I believe I have found the solutions to 99% of crash dump issues, it does not change the fact the game is not without major issues, the games coding causing endless memory leaks that lead to Crash Dumps errors.
So what I'm saying is try to go easy on your database size, either slow or at most medium size data base when starting a new game.
Also dont go crazy with the amount of leagues you select to be playable, if you have a good system 10 leagues at max.
If you must have lots of leagues and large data base I recommend you have at least 6GB of DDR2 or DDR3 ram, if you have an older system DDR ram will not cut it for crazy data base sizes.
3)Everything Up to Date ? - Make sure the following are up to date
+ Graphics Card Driver (Use manfactures site, sometimes windows will not find the most up to date driver)
+ Java - Make sure you have the latest Version
+Direct X - Latest Version your system is compatible with
4) General Settings in Game These are optional but I recommend you use these settings to prevent errors.
Uncheck the following boxes
+Use Skin Cache
+ Enable Data Collection (This is an important one, it will stop FM constantly building up the RAM useage and prevent Crash Dumps)
+ Play in Windowed Mode, Minimize, and Maximize Every Hour.
+ Disable sounds, and 3D cameras, the 3D sucks anyway text all the way.
+Play with Autosave weekly, 3 file rolling save for back ups, better safe than sorry.
+ Uncheck Threading, if you have a Dual Core processor, you do not need this to be checked, it takes away a complication. However if you have one processor with Threading technology keep it ticked, other wise the game performance will be poor.
5) Your Hardware Before Playing FM 2010 you need to be confident your hardware is all fully working, so you can rule that out if you need to trouble shoot in case you get the Crash Dump.
Consider and do the following before installing the game
+Power Supply - Is it at a high enough Voltage for my Graphics card ?, find out and upgrade power supply if need be, you should not be using a Graphics card if your power supply is under the recommended amount, your system will become very unstable, let alone Football Manager.
+Hard Drive Error Free, run Chkdsk, a windows tool to see if your hard drive has any errors.
To run chekdsk press the windows button and R, then in the run box type in CMD, the in the black command box type in chkdsk and press enter.
You should have a report of no errors, or windows will fix errors
+ Faulty RAM - This was the culprit for me, run a program called MEMTEST86, you need to download and Burn it to CD, restart your PC with the CD in the drive and let it scan.
If you are error free all good, if not note which RAM slot is reporting errors, remove or replace that RAM.http://www.memtest86.com/
+Dust Bunnies - Your system would be unstable in general if you have these, if it is a little unstable check the innards of your PC for obvious dust, blow to free dust from sensitive areas.
If you ever get Blue Screen errors while browsing, gaming, multi tasking, then Football Manager will certainly Crash Dump you ***.
Okay if you follow all these steps prior to installing your game you are very unlikely to get the crash dumps error again.
please rate me if this help you thanks...
Jun 05, 2011 | Sega Football Manager 2011
I try to run the game, Momento Mori, on my HP 64 bit late mod laptop. When I try to start it, it says it can start because it's missing d3dx9_37.dll. The .dll is located in Windows/System32, but I get that...
The d3dx9_37.dll error is a DirectX 9 problem. It could be missing or corrupt.
DO NOT download the file from dll download sites because there could be many different reasons why this error occurs.
First of all restart the computer if you haven't already done so as the error could be a one time only issue. Most games require you to restart anyway. Do so even if you are not prompted.
Secondly, if the problem persists try reinstalling the game as it could have been a bad install in the first place.
Also you can download DirectX from Microsoft.com, search for DirectX End-User Runtime. Download and install it. This usually resolves the error.
Regards.
Jul 22, 2010 | HP Pavilion dv9830us PC Notebook
PS3 - Game crash followed by disc read error
The update corrupted your hard drive that's why it's not loading any disc.Yes,Restoring the system will work but it will destroy all your saved game data.Updating the system will not remove the hard disk defect.There is only one solution,Reset it.
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
Ps3 crashes when loading Star Wars: The Force Unleashed for PlayStation 3
are your trying to load a save file??? it may be something as simple as having a corrupt save file. try starting a new game and save and reload that save game. if that works but your other save file you are trying to load doesn't then more likely u have a corrupt save file and there is little hope of getting it back
Apr 09, 2010 | LucasArts Entertainment Company Star Wars:...
On my xbox360 i got the e68 error message and i took the hard drive out, and then put it back once the xbox was on and i went to memory on the system settings and for my main profile it said corrupted...
can you still access anything else that was saved on your hard drive?
such as demos or anything else you downloaded, etc? generally that means your hard drive has over heated, or worse, crashed. but! you got lucky that your whole xbox didn't crash with it. there is a chance you can save your hard drive and all your files. there is a how to here: http://ezinearticles.com/?Xbox-360-E68-Error-Fix&id=2549596
Aug 06, 2009 | Microsoft Xbox 360 Console
Capcom Devil May Cry: DMC Definitive Edition PS4 UK IMPORT Logo
390 people viewed this question
Top Capcom Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Piyal Perera
Piyal Perera
Person On the...
Level 1 Expert
Are you a Capcom Video Game Console and Game Expert? Answer questions, earn points and help others
