Question about Lexmark X2650 All-In-One InkJet Printer
Is this printer wireless? or do I have to use the usb cabl to print?
    Master:
  • Lexmark Master
  • 752 Answers
It seems that wireless is not supported, and you must use a USB cable. Check that the connectors are the correct ones; printer accepts a type B ('house') male connector (plug)
If uncertain consult Lexmark support, or the manual for this printer. Information (including probably a manual) can quickly be obtained from the webpage
All Products Printers MultiFunction Lexmark X2650 Lexmark
The image shows two connectors (which may be on either end of a single cable, and what I think you need) lower is type B (printer end) , upper is type A (computer end, most commonly). Available in various lengths, you need USB 2.0 spec.
Is this printer wireless?  or do I have to use the - 25639017-l5nz1zge0s5jbgweyu4yqzt0-3-0.jpg
Posted on Apr 10, 2015
I recently purchased a Lenovo All in One wireless computer. I've plugged in the USB cable as per instructions but my X4650 printer will still not print.
Have you installed the printer drivers? Is the printer power turned on before plugging the USB cable into the computer? You could have a bad cable. Try a different cable.
Dec 13, 2014 | Lexmark X4690 Wireless InkJet Printer
Hp officejet 6500a plus, usb not printing if both usb and wireless configured
Hi,I understand it must be very frustrating if one is working at a time but not always!!! don't worry I will help. you have two solution ;)One is easy and quick but cant promise how long that will work :Pi.e go to printer page click on add a printer>> select virtual usb port>> select the printer manufacturer as HP >> printer name deskjet 990c and done when eva u will print through usb use this one that will help.NOW THE 2ND ONE:except the power cable disconnect all the cables and keep the printer on>> Insert the CD>> go under my computer/computers >> right click in CD drive>> explore >> util>> CCC> uninstall L2 >> restart the comp>> do a fresh installation dont plug the USB until unless it asks for it. WISH U ALL THE LUCK :D
Jan 03, 2012 | HP Officejet 6500 Wireless All-in-One...
I have an hp pavilion dv4 laptop and an hp digital copier 610.I do not have the usb cable.it's gonna work with wireless?
This is a USB unit. If you use a wireless print server (for a USB printer), you may get some of the functions to work wirelessly. You will need a USB cable to do this. However, most print servers do not handle the bi-directional communication for the scanner. (You will be able to print if you have the correct driver installed.)
As far as I know, this printer can't be fitted with the HP Jet Direct module (this is the internal print server for some of the HP printers). However, there are external JetDirect options: http://h10010.www1.hp.com/wwpc/us/en/sm/WF02a/18972-18972-236253.html . Check the specs for each model to see if they are compatible with your printer. (The first wireless one isn't compatible as far as I can tell.)
USB cables are available at most stores. Make sure to get one labeled A/B Male/Male ends. For best results, the printer should be directly connected to the computer (or connected to a powered hub). The cable should not be more than 6' long.
I wish that I could be of more help.
Nov 09, 2010 | HP 610 Color Copier
MX 860 won't print. Had it working wirelessly and then connected it to the MAC by USB. Now won't print
Hello, Paige.
If your printer worked OK wirelessly, the only problems could be with your USB cable, USB port on your Mac, or the printer driver.
Move your cable to a different USB port and try again.
If still a problem, remove and reinstall the driver.
If still a problem, replace your USB cable.
Hope these suggestions help.
Jan 09, 2010 | Canon Office Equipment & Supplies
HOW DO I USE A WIRELESS PRINTER WITH NO ROUTER. I WANT TO PRINT FROM TWO COMPUTERS, THAT BOTH USE DIAL UP INTERNET
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a wire less network set up and want to use my lexmark x1270 so i can print wireless but cable is USB and do i need to get a cable to put into my router or??
You can't set it up wirelessly, persay. but you can use a special bluetooth adapter in the "pic bridge" slot on the front. I have seen them on e-bay from £5($8) to £12($17) or so.
Oct 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
Printer and computer no communication
Unless you have a wireless router to conduct traffic, you won't be able to print wirelessly to the AIO 966.
You will need a cable (and it's possible the printer didn't come with one). You'll need a USB A-B cable to do this. You can find one at any office supply store, Radio Shack, Target... it's a common part.
Then with with laptop and printer on, plug in the cable to each and Windows should recognize the device and you'll be able to print.
Jul 01, 2009 | Dell Inspiron 6000 Notebook
Connecting from a Mac via wireless print server
Dissconnect USB cable add ethenet cable find printer on Mac set to default should work fine then worry about the wireless side inkypete
Apr 21, 2009 | HP OfficeJet 6310 All-in-One Printer...
Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
Nov 03, 2008 | Dell 948 All-In-One InkJet Printer
Lexmark X2650 All-In-One InkJet Printer Logo
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
