Softener compartment won't empty during cycle and don't know how drawer comes off
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Most pull out and up firmly
Posted on Apr 16, 2015
SOURCE: Fabric Softener doesn't empty
My husband just fixed ours after not seeing a solution on any other site. He pulled out the dispensing unit and pulled off the blue plastic piece on the top of the fabric softener and bleaching section. He then ran warm/hot water (not boiling hot) through the holes where the fabric softener is suppose to flow through. This cleaned out excess fabric softener that had coagulated in the elbow and blocked the flow of softener to the unit.
Posted on Aug 05, 2007
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
SOURCE: Fabric softener stays in drawre
We just had a tech come out to fix this problem for us. Essentially, the problem is that the fabric softener builds up and gets clogged. He cleaned out a solid hunk of frabric softener gunk, and suggested that we dilute our fabric softener with water to keep this buildup from happening again.
Posted on Apr 11, 2009
SOURCE: Fabric softener compartment blocked
The fabric softener section in the drawer on my washing must be blocked as the fabric softener is staying in the drawer. Does anyone know any way to unblock it
Posted on Nov 06, 2010
  • 6277 Answers
SOURCE: Fabric softener compartment won't drain. How can I
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 22, 2011
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Water in the Softerner compartment
The softener drawer cover is designed to siphon out most of the water that runs into the drawer so, when the wash is over, the drawer should always be nearly empty. Unclip and take out the detergent drawer, unclip the softener cover and fill the softener tray with water. Clip the softener cover back on and the water should run out immediately. If it doesn't then a small blockage in any of the 3 pipes in the cover can completely stop the siphon action. Cleaning them out is generally all that's needed.
Apr 06, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Bosch Maxx softener dispenser full of water at end of cycle
it seems that there must be a blockage in the siphon tank softener.
Remove the drawer and wash well, remove the siphon softener (just pull up)
Dec 22, 2013 | Washing Machines
The fabric softener drawer does not empty after a washing cycle so how do I solve this
It is normal for some water to remain in the fabric softener dispenser after the wash cycle is complete
Jan 10, 2013 | Washing Machines
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
The fabric softener container doesn't empty during the cycle of the washing machine. Adding water manually does empty it - so I guess there's a problem with the fossit. The machine opens from the top. The...
It is more than likely that the water inlet orifice is blocked.Get something to poke into the hole or holes in the top of the soap drawer compartment over the fabric conditioner compartment.
This should solve the problem.
Dec 11, 2009 | Washing Machines
Rinse cycle
di you try to remove the drawer completely and check for a blockage under he dispenser itself.(sometimes te fabric softener can get kinda gunky.. if you extend the dispenser you see a little black tab in top left corner, push it down and dispenser will release, just in case you didnt know that
Mar 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Indesit washing machine W103 softener drawer
The softener could be retained in the drawer due to a defective release or controller fault but washing machines are designed to flush the drawer with water to ensure no residue is left to congeal. It may take a service call to find out what the real problem is.
Apr 21, 2017 | Washing Machines
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Fabric softener doesnt release
pop the top cover off the drawer tray and check for buildup obstruction in the holes. then check for valve operation a combo of main cold inlet and bleach valve send water to that compartment.
Dec 29, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
