Question about Dryers
I went to start my dryer, and it just makes a noise and stalls, then cuts out
  • Jorge Rendon
    Jorge Rendon Apr 11, 2015
    Electric dryer no start does nothing Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING. NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position. If you hear a humming/clicking sound from motor area you more than likely have a bad motor. Try this test out to see if u have weak windings or relay/capacitor on motor. Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings Another thing to check is the belt safety switch. With a multi meter. Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
  • Dryers Master
  • 5,323 Answers
Posted on Apr 13, 2015
3 Suggested Answers
beamerguy740
  • 65 Answers
SOURCE: cuts off makes noise
Sound like the dryer bearing or rollers are out. This would make it very hard for the dryer to start and run. You must pull the dryer drum out to access the parts. I'm sure you will see the problem right away once it is apart.
Posted on Apr 01, 2010
heatman101
  • 43501 Answers
SOURCE: Makes loud squeaking noise, cuts off after a few minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bxx
Posted on Sep 29, 2010
I went to start my dryer and it just makes a stalling noise, then cuts out. Everything is plugged in. Just wondering what it could be
Sounds like the motor drive to the drum is frozen. Machine shuts down via overload protector.
Free up the motor and all will be fine.
Apr 10, 2015 | Dryers
Car cut off at red light
Toni, is your car making noises while your driving? Although your lights work, still check the battery level. Make sure everything is the way it should be first. If your check engine light is on, get it scanned at Autozone, it is free. You may have an issue with your transmission or shifting components. Did it continue to make noises when shifting? I need a little more detail please.
Jun 13, 2013 | 2002 Ford Focus
Sometimes when starting 2000 lincoln signature tc the idle will surge as this awful sound like someone blowing a conch shell ?other times w /do same while driving. Only way to stop noise is to push qu
the compressor that pumps up the air suspension does make a horrid noise, and if you can turn it off, like I could in my crown vic, just long enough to see if that is indeed the compressor making the noise you hear, then try that. My switch was located in the trunk.
Mar 21, 2013 | Cars & Trucks
Cuts off makes noise
Apr 01, 2010 | Whirlpool LER5636P Electric Dryer
First start of the day, engine fires up and runs well then stalls
This is a tough one to solve without hearing it myself. There are several things which will make noise, its the stalling that matters. I will give you 4 that can stall a car and make noise.
1.Traction control cutting off airflow to engine.
2.Automatic ride control pump pulling down alternator.
3.A/C pump locking up.
4.Bad Alternator
5.Bad fan clutch or water pump
You should go to Autozone or Oreillys for a free scan of your cars computer.
Mar 16, 2010 | 2000 Lincoln Town Car
85 Nissan stalling, popping noises.
mcdevito75 here, Sounds as though you have a worn or broken timeing belt, or problem with -in the ignition system of the engine. Have the shop check it out for you.
Feb 21, 2010 | 1992 Dodge Dakota
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Kenmore dryer model #11060932990
HAVE YOU CHECKED THE IDER ARM UNDER THE BOTTOM FRONT OF THE DRUM??????THANKS
Jul 23, 2008 | Dryers
Dryers Logo
53 people viewed this question
Top Dryers Experts
