Question about Kyocera Mita KM-2530 Laser Printer
Printer will not scan to PC. Error reads: Unable to find destination PC
This error message appears when I go into the address book to scan to an individual PC
Bubbabear64
  • 2794 Answers
SOURCE: "unable to find destination" ERROR WHEN TRYING TO CONNECT SCANNER.
Are the TWAIN drivers installed on the computer?
Posted on Jun 27, 2008
  • 46 Answers
SOURCE: kyocera 3035 under res. i get e023
The KM3035 requires a second network card for network scanning. then use the scanfile utility on the client machine / server to recieve the jobs and dump in a shared folder
Posted on Jun 11, 2009
  • 37 Answers
SOURCE: scanner (c2520). all of the sudden, when trying to scan a document (we scan to PC...select a sender....save at user PC...and the message we are getting is:incorrect setting of destination folder. cont
1. Use a web browser to go to the machine at the ip address that you assigned to the scanner to check the network connection.
2.you need to make sure that the computer you are scanning to has the "Kyocera scanning utility" installed and running in the background.
Make sure address book is running. In address book editor you can change the path of the destination forlder and the Id# that are linked together.
Hope this will help.
Posted on Jul 08, 2009
SOURCE: Scan error C3200
remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
Posted on Aug 17, 2009
  • 16 Answers
SOURCE: When iam using scanner an
first off let me clarify this its a wireless all in one printer go to menu on the printer go to wlan then you should see wireless setup click on that you must know the password to your router and it must be wireless if you have it setup to secure otherwise :also sometimes you need to know the ip address and enter it also to get it to communicate with the router and other computers.if this doesnt help you need to post more info on what kind of problem your having it can be technical setting up that printer good luck!
Posted on Sep 23, 2010
Ricoh MF Copier, destination list cannot be used now, using ldap,
When it say the list can not be used, it means the hard drive/disk thet keeps your addresses have failed. The fast way would be to format the hard drive/disk and re-program your info. This commonly happens when the hard drive/disk is active during a power surge/failure or incorrect shut down. Go to service mode by pressing yellow button then 107 then hold the red/stop button for more than 5 seconds, when the screen changes press the first option on the screen(should be copy or system), now press 5832 (HD format) and enter/execute, when "completed" is displayed switch off and on. Now open your internet browser on PC, take out the web address and input your printer IP and press enter, username-admin, no password, on the left of the screen click on address book, now go to add, input all you info and press ok, now log out on the top right of the screen and test scanner.
May 01, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
Address book
Where's the address file located. You need to have full rights (Read, Write, File Scan, Modify, Delete, etc) to the Address file. Right-click on the file name, select Properties, view the rights you have to the file.
Apr 14, 2014 | Dymo LabelWriter 400 Thermal Printer
Scan error - Can not connect
If you are scanning from your pc and seeing this error message it could mean that your scan drivers are disassociated. If you have multiple multi function printers or scanners that could be causing the problem as it creates a conflict with the software framework. I would recommend uninstalling the software as well as any other multifunction and reinstalling the software as well as the additional product software.
If you are scanning from the printer it may not be set up and you would have to set up scan destinations.
Al
Eliteprintersolutions@gmail.com
Jul 10, 2010 | HP LaserJet 3052 All-In-One Printer
Error when scanning
Hi Liz
Looking at that message I get the impression that the printer is not actually scanning but trying to 'import' from a non-existent camera card.
You don't normally get an import message when scanning.
The destination full or read only part is a puzzle but could indicate that it is also trying to copy back to that non-existent card.
I think your best option is to use Canon's web site and look at the support section. They may well have an on-line chat service in your area that can help you sort it out.
May 19, 2010 | Canon PIXMA MP470 All-in-One Printer
CF2002 Trouble Scanning to Email
scan to email can only be setup to work on a internal email server if the email server is external it will not work. also make sure you input the admin email address and the from email address when configuing the machine
May 14, 2009 | Konica Minolta Office Equipment & Supplies
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Scan to folder problem
Delete your Driver for this multi, I use revo-uninstall a free removal tool that cleans the registry. Then download the up to date driver package and reconnect your device.
Regards
Sir Dana Taylor
Apr 23, 2017 | Kyocera Mita KM-2530 Laser Printer
Scanner will not connect to PC
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Dec 28, 2007 | Kyocera CS-2550 Black and White Copier
Kyocera Mita KM-2530 Laser Printer Logo
71 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
