Question about GE Refrigerators
I have GE profile refrigerator with bottom freezer the indicator light to replace the water filter came on I did so but it will not pump out water I held the reset button for 3 seconds still nothing
  • GE Master
  • 473 Answers
Double check the filter install you did. Make sure there isn't any clear plastic seal over the center hole of the filter and retry the water. If it worked before the problem has to be in the filter install or the filter is possibly defective and wasn't manufactured properly. The reset button is only for the warning light---has nothing to do with filter or water operation.
Posted on Apr 10, 2015
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Refrigerator is freezing food AND broken ice container part.
Just lower it one number at a time , wait 24 hrs each time you re set it until you reach the right temp. 34-40 deg.
Your filter light has not came on most likely because it has not had the time to. You do not need to replace your filter every six months. This is a safe guesstamate from the manufacture , it depends on water quality and use of water , some filters will go years and years , the filter indicator does not even know if the filter is bad.
When you notice water pressure slowing when dispensing from the door you know the filter needs replaced.
Hope this gets you out of that service fee. This should FIX IT!
If you have any questions let me know.
Phil
Apr 14, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Dispenser on freezer door
Check the electrical connector at the bottom of the freezer door for corrosion and if it is not that then the main PCB is failing , when it fails the appliance will stop working altogether although the lights will still work inside.
Jul 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
