Question about Kenmore Dryers
The dryer won't run and the flow sensing was flashing
I had Kenmore elite electric dryer, bought at 2010, When turned on the dryer won't run and flow sensing was flashing
  • Anonymous Apr 14, 2015
    There is a YouTube video show you how to put the belt on, now my dryer is up running now, thank you for all the help provided, and you all have a nice day :)
  • Kenmore Master
  • 5,323 Answers
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Posted on Apr 13, 2015
  • 1 more comment
    Opened the dryer's back cover today and found out the belt was falloff but didn't see how to put it back the belt was too lose
  • Jorge Rendon
    Jorge Rendon Apr 15, 2015
    glad u took care of it
  • Moses Soto
    Moses Soto Aug 24, 2016
    Did you get it fixed
    New Friend:
Did you ever find what was causing the issue
Posted on Aug 24, 2016
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
Note: Make sure you order the correct thermistor for your dryer
Dec 05, 2012 | Dryers
Dryer takes a long time to dry
If the dryer won't takes to long to dry, check the venting. A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time.
Nov 12, 2012 | Kenmore Elite HE4 Electric Dryer
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
Model # 11061082000 electric dryer....elite kenmore
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
Dec 28, 2017 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Dryer makes thumping noises when it is not running.
if it is not running and you hear noises. you may have a critter in the vent,or it may be flow reversal from another fan being used, oran outside door beingopened or shut. karl
Oct 28, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
297 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
