Question about Midland Radio Communications
When I key up my Midland GXT797 radios all elements on LCD screens light up and flash. Radios receive but won't transmit. Batteries are fully charged and it does this on all channels. Suggestions?
  • 21 Answers
I would take a cloth and give battery contacts and contacts on the radio a good rub, sounds like a dirty contact.
Posted on May 10, 2015
Benimur
  • 6966 Answers
SOURCE: Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 06, 2007
eradiostore
  • 1654 Answers
SOURCE: won't receive or transmit
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Posted on Aug 21, 2008
  • 157 Answers
SOURCE: Midland rechargeable battery packs won't recharge and vibrate
Hello batterbum, from the info you listed you have the right battiers & charger, with alkaline the radios work leads to wrong or a bad batch of Ni-MH battiers. Vibrations from a battery pack states too much current being drawn for battery capacity. Note: depleting a battery and recharging with a charger will place the battery in a false full charge state. Recharging a depleted battery with a DC power supply with current limit can reboot the battery to a 90% cycle. I suggest returning battiers for correct replacements, if they are correct 'by the book' ask for the highest in mAhr specs. Please inform me of your outcome. Good Luck
Posted on Nov 07, 2008
  • 157 Answers
SOURCE: midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
eradiostore
  • 1654 Answers
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Posted on Dec 26, 2008
How long will my four aa batteries last in my walkie talkie
Typically you can expect the AA batteries to last about 18 hours using the 5-5-90 rule. (5% of the time your are transmitting, 5% receiving, and 90% standby) If you transmit/receive more than this the time the radio would go would be shorter.
Best regards.
Jun 04, 2014 | Midland LXT310 2-Way Radio
I can recieve transmission from a motorola t5400 but cannot broadcast
Are you on the same channels? Are you on a repeater setting? What are your squelch settings?Are your batteries fully charged? Power is needed on transmit, not so much on receive
Mar 27, 2014 | Midland LXT310 2-Way Radio
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
Nov 10, 2013 | Midland Radio Midland X-tra Talk Frs/grms...
One walkie not transmitting
Swap batteries between the radios and see if the problem moves to the other radio.
If your charger does not light up, it is not working. So your battery may not be getting fully charged. The first sign of a poorly charged, or bad battery is no transmit.
If these do not solve the problem, and your settings are identical, you may have a faulty radio. Double check your settings, and take them back to their simpliest form, shut off any special features and make your PL code be off or zero. Then try the radios, if they still don't work, you have one radio which is bad.
best regards.
Jul 14, 2012 | Radio Communications
I have a problem with radio gxt1050, it was functioning correctly, but now I turn on it and the keys not response, no PTT button, but I can hear calls from other radios... tanks
  • It takes a lot more power to transmit than it does to receive. So it is possible to listen but not be able to talk. Make sure that the batteries are charged and that the batteries are holding a charge. When batteries begin to fail they won't hold a charge for long at all.
Regard, Tony
May 06, 2011 | Midland Two Way Radio
Midland GXT 950 two way. TX problem
I am sure the OP isn't likely monitoring this, but just in case anyone else needs it... It's a power problem. Try charging the batteries, even though they look like they're fully charged -- or replace with 4@AA batteries.
This only seems to happen on the GMRS channels -- not the FRS ones. The radios come default to transmit at high power (the full 5 watts) on the GMRS channels, but only 0.5 watts on FRS. If you go to settings and change the power on that particular channel you're trying to medium or low, you'd likely find it works with the charge you had problems with.
Recharging or changing to 4@AA batts should get you back up to continuous TX on those high-powered channels.
Jul 04, 2010 | Midland Two Way Radio
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Sep 27, 2009 | Midland 1001Z 40-Channels Base CB Radio
Midland GTX800 "X-Tra Talk" 2-way radios will not transmit
Are you sure that the batteries are running well?
Try using alkaline batteries just for testing.
Jan 17, 2009 | Midland 20-Mile, 22-Channel FRS/GMRS 2-Way...
One radio continually transmits
Hello
This could be the Ptt Switch , Midland is 3 Years warranty try to claim the warranty, this is a Factory fault.
Oct 25, 2007 | Midland LXT303-A 2-Way Radio
Radio Communications Logo
195 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
