Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
What are the tune-up specs for a 17 hp Kawasaki engine?
A briggs and stratton 547cc equals what hp
CCs can't be directly correlated to HP. They are measuring different things. It depends on how the engine is tuned. You can approximate that small engines 1 HP = 30 - 32 CC, car engines are usually 1 HP = 15 - 17 CC. So, 16.5 HP or so.
Mar 22, 2017 | HP Measuring Tools & Sensors
I have a kawaski FH541V and is liking oil by the oil filter compartment, what should i do?
I would try tightening the filter or changing the filter the gasket could be bad on filter
Sep 19, 2013 | Kawasaki Engines NEW 17 HP KAWASAKI ENGINE...
I am looking to check and see if by the stamp on my kawasaki motorcycle engine you can tell me what year and model the engine is
The engine number is worthless. The frame number is the key. If your bike is 1980 or so, pray that it has 17 alpha numeric digits in the number. Les than 17 and finding the information requested is pretty hard. If it does have 17 digits, go to this website http://www.motoverse.com/tools/vin/kawasaki.asp tombones49_296.gif
Sep 18, 2011 | 1980 kawasaki KZ 1300 A2
A Kawasaki lawnmore engine has no spark Not sure
This engine is made for a "Self Servicing OEM" That means I can not get information on the exact spec of the model you have but I looked up a different spec that has the same basic hardware.
This engine has an igniter.
Call a local shop like www.arcolawn.com or order online the kawasaki
* 21119-2119
IGNITER $91.13
Good luck
Aug 18, 2010 | 1990 kawasaki ZXR 750
Tune up specs needed
1968 Barracuda with a 318cid; The 5th digit of the vin will be (F) for the engine-318 2v rated @ 230hp.
Compression pressure--125-155 max variation 25
Spark plugs--Champion N-14Y @ .035" gap-torqued @ 30ft. lb.
Timing--man. trans @ 5 degrees btdc, auto trans @ 10 degrees btdc.
Points-- .014"-.019" gap--Dwell--28-33 degrees, max variation is 2 @ 1500 rpm--Spring tension--17-20 ounces.
Fuel pump pressure 5-7 lbs. manual pump
Hydraulic Lifters--no valve clearances
Firing order--1-8-4-3-6-5-7-2 counterclock wise rotation
Idle speed--Turn headlights on highbeams and turn a/c off
500rpm for man trans--500rpm auto trans in neutral.
Left bank of the engine (driver's side), 1-3-5-7 Right bank (passenger side), 2-4-6-8
May 22, 2009 | 1983 Plymouth Gran Fury
Canaballing parts
Hello tim38663:
Depending on the Engine Model and Spec this Tecumseh Usually has the Same External Parts as a 15 HP to the 18 HP Single Cylinder Tecumseh Engines.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
