Question about Swisher 44-Inch 12.5 HP Trailcutter #RTB12544
I have an 11.5 hp Briggs It will start 2-3 times and then nothing NO spark. plug is new, I suspect the coil, what do you think?
It's a 44 trail cutter but it's an 11.5 hp motor Model #217802. Could you tell me what the gap between the coil and flywheel should be. I'm sure it's not grounding out.
    Top Expert:
  • Swisher Master
  • 10,875 Answers
Use 2 thicknesses of a match book,or .012,,pull the black wire off the coil and start it,if it runs then a safety switch is bad
Posted on Apr 10, 2015
  • Victor roberts Jun 21, 2015
    Had same problem safety switch buy the belt .i wired mine direct . Had trouble with it every time I mowed
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Briggs 21 hp OHV motor will not start after internal work.
most likely that the timing is not correct
you line up the dots on the crank gear and the cam gear not the flywheel and the the crank shaft dot
the plug will spark every time the flywheel magnet passed the coil
Apr 05, 2017 | Briggs & Stratton Briggs Stratton Intek V...
Briggs vtwin 21 hp - Only running on one cyclinder. I think- started up let run for 10 minutes one valve cover warm the other nothing still cool. mower has half the power as it did a year ago- ? help
Pull the spark plugs
Attach back to the plug wires and ground the metal plug body to the engine casting one at a time
Crank engine look at he spark
Does it fire equally on both plugs
Does the spark go only to the electrode or does it shoot sideways to the edge of the plug?
If one plug does not fire at all then you have a bad coil on that cylinder
Mar 31, 2010 | Garden
8 hp briggs no spark,new coil ,new electronic
make sure the plug wireisn't grounding on sheet metal. Verify current to ignition module and that module is securely mounted for grounding. Negative side of coil to module, pos to ignition switch or starter button . Chk for current at coil +. . Coil -- should pulsate when cranking. Ensure there are no inline fuses, fuse box fuses, or fusible links incorporated into wires lesding to module. Good Luck_Ned_
Oct 31, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Logo
107 people viewed this question
Top Swisher Garden Experts
Tim Whalen
ray gallant
john milligan
Are you a Swisher Garden Expert? Answer questions, earn points and help others
