Question about Coby Televison & Video
The remote quit working suddenly. what would cause that. it is fairly new
  • 1,140 Answers
Dropping it on to the floor could break it internally. Sometimes some remotes controls fail due to components in the electronic circuits that are defective.
Posted on Aug 11, 2015
Drivers side window wont work and power locks dont work ,mirror works, passenger window works
I have the exact same problem. Fuses look good, I have no idea what the problem is?
Jan 16, 2010 | 2005 Chevrolet Colorado
2001 ml320, remotes quit working. new batteries,
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Programming
When
Key remote control added or replaced. System malfunction.
How
Keys can only be programmed using diagnostic equipment
Jan 09, 2010 | 2002 Mercedes-Benz C-Class
Blower doesn't work.
SOUNDS LIKE A FAULTY HEATER RESISTOR..LOCATED UNDER DASH ON PASSENGER SIDE..PICK UP A NEW ONE..EVEN FAIRLY CHEAP FROM DEALER..YOU MAY HAVE TO TRIM OPENING WITH AN UTILITY KNIFE TO GET NEW ONE IN..FAIRLY COMMON PROBLEM..THE WIRING CONNECTOR TO IT MAY BE DAMAGED ALSO..MELTED FROM EXCESSIVE CURRENT DRAW..YOU MIGHT NEED A BLOWER MOTOR AS WELL..MAY CAUSE CONNECTOR/RESISTOR DAMAGE
Jan 01, 2010 | 2002 Dodge Dakota Club Cab
The remote all of a sudden quit working.will work
needs to be reprogrammed do you have your manual
Jul 01, 2009 | Audio Players & Recorders
Garage Door Remote Openers Stopped Working Suddenly
Check the wall control. If the small green light is blinking press and hold the button with the lock icon for 3 seconds.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
My tv suddenly quite working with the remote. I
Will the TV turn on using the power button on top of the TV itself?If not,open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Feb 25, 2009 | TruTech PLV16190 Television
Buttons on the TV Display quit working
The control circuit board assembly most likely has to be replaced, or the circuit board that has the control circuits has to be replaced.
The only basic thing you can do is open the set and look for any loose connections. Beyond that, there is nothing you can do yourself.
Many times when cleaning the screen people tend to use too much liquid cleaner and they get drops of liquid in to the set through the lip of the bezel. This will usually cause damage to any electronic areas that the liquid comes in to contact with.
Take care, these sets can be fairly expensive to service.
Jerry G.
Feb 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Remote not working
try resetting it by removing the battereis, pressing every button one at a time, then re code for your unit.
Nov 25, 2008 | RCA 3-Device Universal Remote
Televison & Video Logo
66 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
