CARTRIDGE ERROR MESSAGE x4560 MODEL
HAVE CLEANED CONTACTS BUT MESSAGE STILL PRESENT
  • 5,631 Answers
If it is new, return it for warranty, should be changed for a new one. If warranty has expired, there's nothing to do by dispose it and buy a new one. The printer cartrige, as simple as it may look, is a very complex electronic disposable device. Posted on Apr 10, 2015
HP Photosmart 5180 has ink cartridge problem, Says following ink cartridges appear to be missing or damaged.
Solution
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.NOTE:The printer will not operate unless all six ink cartridges are installed Step one: Reset the printer Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.Without turning the power off, remove the power cord from the back of the printer and from the wall socket.Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.Check the printer for the error message. If the error message still displays, go to the next step.Step two: Clean the cartridge contacts Lift the top cover. Figure 1: Lifting the top cover Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch.Figure 2: Unlatching the cartridge 1 Black cartridge 2 - Color cartridges Remove the cartridge indicated in the error message.Figure 3: Removing the cartridge Gather the following cleaning materials:Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.Lightly moisten the swab or cloth and squeeze out the excess moisture.Holding the cartridge by its handle, wipe the copper contacts.Figure 4: Wiping the contacts 1 - Copper contacts Replace the cartridge and then close the latch and the printer top cover.Check the printer for the error message. If the error message still displays, go to the next step.he printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Oct 04, 2011 | HP Photosmart C5180 All-In-One InkJet...
Incorrect cartridge error message when I replaced the cartridges with two new original HP cartridges. HP95 & HP96. The printer will not print. I have turned off and on the printer. I have rebooted...
HpCartridge issue Completethe steps below in the order presented to resolve the problem. It might not benecessary to complete all of the steps. Stepone: Reset the printer
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Steptwo: Clean the cartridge contacts Figure1: Lifting the top cover clip_image001.gif
  1. Lift the top cover.
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure2: Unlatching cartridge clip_image002.gif 1- Black cartridge 2- Color cartridges
  1. Remove the cartridge indicated in the error message.
Figure3: Removing cartridge clip_image003.gif
  1. Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  2. Lightly moisten the swab and squeeze out excess moisture.
  3. Holding the cartridge by its handle, wipe the copper contacts.
Figure4: Wiping the contacts clip_image004.gif 1- Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Stepthree: Replace the cartridge
Dec 21, 2010 | HP Photosmart 2610 All-In-One InkJet...
I was installing the yellow ink and then all the sudden after I installed it the message Error Oxc18a0301 appeared! How do I fix this?
Shut down your printer by pressing Simultaneously Cancel + OK + Black + Color.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or re manufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Lift the top cover. Figure 1: Lifting the top cover
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts (1) - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Nov 24, 2010 | HP Photosmart C6280 Printer
Error OXC19a0031 Ink system failed came up while printing. Printer will not work. Never had any problem before. What do I do?
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Lift the top cover. Figure 1: Lifting the top cover c00813643.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge c00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge c00372273.gif
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts c00372274.gif 1 - Copper contacts
Oct 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
My printer keeps saying cartridge error but nothing appears wrong with cartridges.
hi
Completethe steps below in the order presented to resolve the problem. It might not benecessary to complete all of the steps. Stepone: Reset the printer Withoutturning the power off, remove the power cord from the back of the printer andfrom the wall socket. Wait 30seconds and reconnect the power cord to the printer and to the wall socket.Turn the unit on if it is not already turned on. Check theprinter for the error message. If the error message still displays, go to thenext step. Steptwo: Clean the cartridge contacts Figure1: Lifting the top cover clip_image001.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch. Figure 2: Unlatching cartridge clip_image002.gif
1 -Black cartridge 2 - Color cartridges Remove the cartridge indicated in the error message. Figure 3: Removing cartridge clip_image003.gif
Figure4: Wiping the contacts clip_image004.gif 1 -Copper contacts
Oct 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer reads out "Carriage Jam". Have done all the usual stuff.... shut down,unplugged, cleaned around connections and still reads out "carriage jam". Makes a lot of noise after opening carriage and...
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hp Cartridge issue
Lift the top cover.
  1. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
1 - Black cartridge
  1. Lightly moisten the swab and squeeze out excess moisture.
  2. Holding the cartridge by its handle, wipe the copper contacts.
1 - Copper contacts
Jul 29, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Ink cartridge error
Hp Cartridge issue
1 - Black cartridge
1 - Copper contacts
Jul 13, 2010 | HP Officejet 5610 All-In-One InkJet...
Replaced the ink cartridges but the printer telling me there is no ink?
Hp Cartridge issue
1 - Black cartridge
1 - Copper contacts
Jul 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer not printing
When this error appears in your printer check if ink are smeared on the holder where the contact panel is with the cartridge. To fix this issue use the Kleenex (perfume ) added with few drops of water to dampen it and clean off those contact on the holder. You should let the unit sit 24 hours for best results. Before printing anything run aligned the cartridges a couple times then run clean cartridges a couple of times. Print the test page to look for the condition.
Thank you !!
Jun 28, 2010 | HP Officejet 5610 All-In-One InkJet...
Installed new cartridge, still displays empty
Hp Cartridge issue
1 - Black cartridge
1 - Copper contacts
Apr 22, 2010 | HP Photosmart 3210 All-In-One InkJet...
64 people viewed this question
k24674
