Question about NEC Office Equipment & Supplies
Why won't the lamp stay on?
I have a ceiling mounted NEC NP-M260X projector. The clean filter message came on - not sure how long it had been on as no one noticed. One day the bulb started shutting down after a minute or so. I cleaned the filter and reset the filter hours but it still only comes on for a minute or so. Barely enough time to check the menu items. It is on auto eco. It is showing about 58% lamp life left. There is a small blinking red light which apparently means a lamp problem.
SOURCE: Shutting off Filter Cleaning Message
you need to turn OFF the message function under the expert tab on the "on screen menu"
In the state of Power ON, press each key in the order of: HELP, UP, LEFT, HELP
Press the Menu Key to display the menu and confirm that Expert is displayed below the menu.
Once you go into Expert mode, go to the Expert2 tab in the onsreen menu and set the message to OFF.
Hope that helps.
Posted on Oct 02, 2008
SOURCE: Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Posted on Oct 07, 2008
  • 736 Answers
SOURCE: NEC NP1000 powers up, strikes, then shuts down
the expected lamp life is an average .. its not unusual to see early failures ... check the lamp connections to make sure they are secure ... check ventilation to make sure its not blocked by dust .. if there is a fan, make sure its working ..
Posted on Oct 07, 2009
leusnerdus
  • 54 Answers
SOURCE: projector gave a message that it was overheating and then shutoff
chek if all fan are running. check if any extrange thing is in the grids. anyway is better to take it to service.
Posted on Apr 20, 2010
  • 22 Answers
SOURCE: NEC NP 1150
The temperature in the classroom is to hot. Turn down the
temperature in the classroom or get a small fan and place it near the
projector. The projector is running at border line and just needs a few
degrees of cooling...
Posted on Jul 21, 2010
Whin i plug vga cable screen flickering
Hi Prakash
Clean Connector Pins with spray
Wiggle to see if bad connection
Check for Female socket loos worn holes in connector pin
Sep 12, 2015 | NEC NP-M260X LCD Projector
Nec NP-M300w computer inputs flicker on and off
It seems that the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2014 | NEC NP16LP Projector lamp RPLMNT LAMP FOR...
Nec np-m260x red lite nine time bliking
your dynamic contrast function is not working properly. you might need to take it in to get repaired
Mar 02, 2014 | NEC Office Equipment & Supplies
After around 1 minute the lamb goes off and the system goes to standby
the lamp is good one, it is ok .the mother board is ok
it seems like the fans is defective
pls check every fan in the projector
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 21, 2014 | NEC M260X LCD Projector
Reset lamp hours nec projector np-ve281
If you wish to get some details; check the site linked here. Pull up older posts.
Jan 26, 2014 | Nec Display Solutions NP-VE281 DLP...
What causes inside the lamp to shatter. It is a NEC Lamp NP21LP. Projector is mounted to ceiling so it uses same power sources and doesn't get moved around.
Have a nice day!
Jerry
Lampdeng Limited
Jan 23, 2014 | NEC Office Equipment & Supplies
My nec np-m300x has a dynamic contrast error. How do i repair this?
9 Blinks is IRIS error the motor can sometimes produce a clicking sound part number 24B17981. If you pull it out and manually move the metal apart the projector should come on and stay on
Jan 23, 2013 | NEC NP-M300XS- Xga Lcd Proj 3000lumen Shrt...
How to replace NEC NP 07 Lp projector lamp
lamp USD70
Have a nice day!
Jerry
Lampdeng Limited
Jan 10, 2013 | NEC NP07LP Projector Lamp
I have an nec mt850, my picture is upside down...how do i fix that?
Unit is probably set for ceiling mount or reverse screen projection. In the options menu there will be settings to alter it back to normal aspect.
Apr 28, 2012 | NEC MT850, MT1050, MT1055, MT1056...
Need to replace NEC Lamp Unit in VT75LPE. Unit is bolted to ceiling in library and unable to be detached easily. What is procedure for replacing lamp?
Hi. You are most likely going to have to remove the projector *and* the projector mounting plate in order to access the lamp door. Mark the orientation of the projector mount plate with a marker and set aside. Remove the lamp door with a proper screwdriver. The PROJECTOR MUST BE COOL TO PROCEED!! The lamp will be secured, usually with 2 screws. Loosen these screws--new screws should come with the new lamp--already held in position. Using the hinged metal handle, pull the old lamp straight up and out of the projector. ( you might have to wiggle it and work it out steadily--its a precision fit) Take your time and *don't force* it! Carefully slide the new lamp into position, taking care that the power connector on the lamp assembly is properly seated. MAKE ABSOLUTELY SURE YOU DO NOT TOUCH ANY LAMP GLASS WITH YOUR FINGERS!!! If you do get finger prints on any glass surfaces, carefully wipe them off completely with a dry, soft cloth--DO NOT USE CLEANER!! This is critical to the life of the new lamp--finger oil attracts heat and will cause the new lamp to fail pre-maturely. Re-attach the lamp door--make sure you don't over-tighten any screws on lamp or door--they need to be firmly tight but not "gorilla" tight! lol Clean any dust filters thoroughly before re-attaching the mounting plate--you'll be glad you did! After re-mounting the projector, power it up and go into the menu in order to reset the lamp timer.--Hope I helped you!---Rick
Dec 30, 2009 | NEC (VT75LPE) Projector Lamp
94 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
