It is printing a black sheet of paper. - Office Equipment & Supplies
  • 5,631 Answers
This kind of failure is hardware related. If it is still on warranty, you should return it. If warranty epired, take it to repair but if the printer is old, might be quite difficult to get it repaired because of lack of parts.
Posted on Apr 10, 2015
Prints total black sheet of paper
If there are no indicator lights, it's probably a defective cartridge.
Apr 23, 2016 | HP LaserJet 1020 Printer
When printing black dots appear chaotic, over the entire sheet of paper. What to do?
If the black dots appear on every sheet of paper it could be the fuser unit is wearing out or the drum unit. The way to check that is to stop a print half way through and remove the paper. If they are not there before the fuser unit but after it then it will be the fuser. Or if they are there before the fuser unit it will be the drum unit. If it they only appear specfic to one source then it is likely to be the source of the document. IE copying - check the optical area (scan glass etc). If on incoming Faxes it may well be the sender that has the problem and is just transmitting them to you. Hope this helps.
Sep 09, 2015 | Canon iRC2380i
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
May 02, 2011 | Brother HL 2140 Laser Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Black only on photo-paper
Print out a demo sheet. Press copy and photo at the same time. If the black isn't printing on this demo sheet, (the eyes on the two kids at the top are all white), you need a new printhead. contact kodak tech support. 18004216699. Option 1
Oct 11, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lexmark x1180
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 13, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
64 people viewed this question
k24674
