Question about Uniden DECT 6.0 Cordless Phone
What does Check TEL line mean. I can'y find any physical issues with the connectivity.
I can't call out. And my DSL line is fine for a change.Everything is plugged in.
    Top Expert:
  • Uniden Master
  • 34,190 Answers
The message means some kind of problem has been detected in the line. It could be hum or static, possibly caused by a technician fixing someone else's problem.
Posted on Apr 10, 2015
Internet signal keeps dropping
There's a lot of possiblities here.If you have a DSL/dialtone lineshare,listen for noise on the line(humming,crackling static,dropped calls).If you have a dry loop(DSL only),connect a phone in place of the modem and see if it has an "intercept" message(like "you have tried to call a number out of your service area" or something like that).If it does,you can use a phone to check the line when the DSL drops(don'touforget to put an inline filter on it).If the DSL light doesn't go out when the Internet light does,it is NOT a problem with the physical line.This would be an issue with the modem or the equipment at the serving end.( I am a DSL tech,and spend lots of wasted time diagnosing and trying to fix problems that are beyond my reach(central office server issue) or that I didn't need a dispatch for(it is cheaper to send a new modem than to send a tech).
Jun 02, 2012 | D-Link DSL-2640R Wireless G ADSL2 Modem...
My DSL Light is not on but my wlan light is on but I can not connect
If your DSL light is not on, that might mean your modem is not connected to your ISP's DSL network. Check the cabling, specifically make sure the telephone cable running from your modem to your telephone socket is plugged in correctly. If that's ok, contact your ISP's helpdesk and ask them to test your DSL connection. It might be a mass outage in your area or a technical issue with your DSL line.
Mar 12, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
The tel 1 and 2 buttons are flashing green along with stand by. The phone line has no dial tone and its busy when we call the line..
When the tel light blinks this indicates that the line is in use. To trouble shoot this issue you will need to connect a phone directly to the tel 1 port of your modem. If you have dial tone when directly connect that means that there is an issue with the internal wiring of the home. If you still do not have any dial tone with the phone directly connect than there is an issue with the modem and it needs to be replaced.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 25, 2010 | Arris SURFboard SB5120 Modem
The dsl light on my modem isn't lighting up?
The dsl light is physical connection to the internet. If your dsl is a line share with dial tone and it sounds clear with no humm or static, your lines are most likely in good working order. So you may start with the telco tech support or better yet borrow a friends working modem and see if you get dsl at your place. This will tell if a dsl signal is making it to your jack. If it is then your modem is toast. If no dsl with a known good modem the issue is with you isp/telco. Most telcos charge a $60.00 isolation fee if the dsl signal is good to your home/business. So a little work on your part can save some cash.
Mar 20, 2010 | Arris High Speed DSL Modem
Modem, all lights come on, dsl light blinks red...what does this mean?
It, means either your username pass word is not correct or the DSl line issue,
Jul 29, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
I have a speedstream 4100 , it has 5 lights one for activity and the others are allways when its working right. sometimes the first 2 will be green and the dsl light will flash red then green & go normal...
You will need to contact your DSL provider to come out and physicly check the lines. I had the same issue, and it turned out to be a faulty line.
Also you should be able to reset your device by logging into it on the LAN connection by putting a spacific IP address into your address bar of your browser, common IP's for modem's / DSL routers would be:
192.168.1.0
192.168.1.1
192.168.0.0
192.168.0.1
192.168.1.254
192.168.0.254
Again, you may need to have your lines checked by yuor DSL provider to rule out improper line installation, or improper line filters
May 05, 2009 | Computers & Internet
Connection of Canon Multipass C3500 to Juno DSL phone line.
Read the instructions again again...u probably got it set up wrong..
Aug 08, 2008 | Office Equipment & Supplies
Re: Frequent line drop
Easy way to diagnos is call ATT DSL support and ask them to run a line noise test. This will check the signal getting to the gateway. If everything tests fine there is usually an issue with the device.
Jun 04, 2008 | 2wire 2700HG-B Router (2700HGB)
Hi and help please :)
1.       Check the for the Physical connection Between the router and dsl  the  modem
2.       And make the sure the dsl light or the status is solid green in the dsl modem
3.       If the dsl light or link light is bilking on the dsl modem . call your service provided and run a line test to confirm if there is any problem with the telephone line
Oct 16, 2007 | D-Link AirPlus DI-524 Wireless Router
Westell Linksys 327W
Ok right I love these issues. Here we go!! First I want you to determine if this is a no sync issue or if this is a no route issue. Know this is the difference between working with Verizon or working with Verizon On-Line. If you have a sync issue which means the DSL light is off or blinking, this would be a Verizon proper issue and is easy to have fixed, however if the DSL light is on and the internet light is off this means that you have not received a PPPoE derived address and thus while you have DSL (Digital Subcriber Line) sync you do not have connectivity to a gateway router to route you to the Internet. I want you to log into you DSL modem (http://192.168.1.1) then using your login ID and Password the one you configured for the Router not Internet access. And the go to the screen that show your DSL connectivity see if it is up or down *Remember DSL refers to the layer 1 connectivity, and PPPOE refers to the layer 2 connectivity". If the DSL light is on this meaans that you have to call verizon and say "My DSL light is on, but I am not getting an IP address which means my layer 1 connectivity is working, but my layer 2 PPPOE connectivity did not provide the platform for my layer 3 level to be built". so this now becomes a task of troubleshooting the layer 2 systems (PPPOE server, and IP Address delivery systems, and Redback SMS). Instead of a half hour of "is your modem plugged in". If your DSL light is off then your layer 1 systems are not working this could be anything from your modem to the ASAM ( ATM Subscriber Access Multiplexer ) system or DSLAM (Digital subscriber Line Access Multiplexer). In any case if the DSL light is off they just have to figure out why. This can be done at the central office by disconnceting your cable and pair and trying to sync up at the vertical shelf (Ca/Pr) or at the split bank. If they sync up the problem is outside, if they do not sync up the problem is inside the CO either at the Split bank or the DSL OE block. If the problem is in the CO they will fine and fix it. If the problem is outside, what you can do to expedite things is to take your DSL modem to the NID (Network Interface device) and connect to the phone line that has DSL on it and try to sync up there. If you can sync up the problem is inside of your house, if you can not sync up the problem is outside of your house prior to the NID and thus is verizon's responsibility. I hope this helps.
Sep 06, 2007 | Westell Wirespeed VersaLink...
Uniden DECT 6.0 Cordless Phone Logo
262 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
