Question about Singer 20u Sewing Machine
The presser foot won't go down.
Singer 20u machine, always worked fine until yesterday. Now the presser foot won't go down. I can see that when the presser foot is raised as high as it will go, the tension releasing lever part # 541700 slips off its lifter, drops down and inserts itself underneath the lifter, blocking the presser foot from going down again. I can push the tension releasing lever back into place and the machine will sew fine until the presser foot is raised to its full height again ie be careful just to raise it part way and it will continue to sew. Is it possible to tighten up or otherwise adjust the tension releasing lever?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
Yes indeed, it is possible--sounds to me like a screw worked itself loose. However, I would purchase the service manual for your machine. As a bonus, it tells you how to make all kinds of useful adjustments.
Go to Sewing Parts Online and do a search under Singer Service Manuals; if they don't have it in stock, call or email them and they will be happy to order it for you. Generally takes two weeks to get it in stock.
Posted on Jul 06, 2015
  • 323 Answers
SOURCE: Presser foot lever stuck
You lever doesn't work because the presser foot Bar is seized from lack of use.Open the side of the machine to access the bar. Put a mixture of water and ammonia ( about 80%water 20% ammonia) on the top and bottom of the bar. Let it sit for 15-20 minutes then try to move the presser foot Up by lifting the foot with a screw driver. Do not pry so hard you break something. It should get progressively easy the more times you do this. Put some sewing machine oil on the top and bottom of the shaft and it should be good to go.
sewman7
Posted on May 31, 2008
  • 27 Answers
SOURCE: I have a Singer sewing
more than likeley the set screw is loose on the presser bar shaft ,remove the endcover and take a look should be simple
Posted on Jan 10, 2009
SOURCE: The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Posted on Jan 03, 2010
SOURCE: hello I have a singer model 4552
I have a used unit with the same problem. If you remove the plastic housing piece on the far left you can see how the foot lifter works. Raising the lever raises a collar around the main shaft. There is a screw in that collar which connects the collar with the shaft. If that screw is loose the collar will not raise the shaft. Caution: Tighten the screw very carefully, only enough so that the shaft lifts. I just overtightened and the collar has a crack now.
Posted on Sep 09, 2010
  • 1456 Answers
SOURCE: feed dogs will not raise, I have lifted the
Hello
First, lift the presser foot; next, push the feed dog lever to the raised position; finally, turn the handwheel towards you until you hear the feed dogs snap into place
If it doesn't, you will have to run a maintenance check on your feed dogs,
Unplug the machine and examine the feed dogs. The newer machines have metal feed dogs, but older models may have rubber ones, which often need replacing. Examine the feed dogs and check for damage.
Remove the throat plate, which is the covering over the feed dogs, and clean it with a soft cloth. Use a small soft brush to clean the feed dogs. Make sure to remove all lint and thread from the grooves of the teeth. Some machines have an adjustment that lowers the feed dogs for specific sewing procedures. They should be in the raised position for better viewing during the cleaning process.
Clean the area around the feed dogs with a soft brush. Compressed air is a good choice to use in the small tight areas.
Wipe down all areas with a clean, lint free cloth before replacing the throat plate.
Prepare to clean the feed dogs and all other areas that lint may accumulate on, after every project. Your sewing machine will last longer and need fewer repairs if kept clean and lint free.
Always unplug the sewing machine before any type of maintenance or cleaning.
Never use a sharp tool when cleaning the feed dogs as this may cause damage to the sewing machine.
Posted on Apr 16, 2011
Presser foot doesn't go down. Presser foot lever goes up and down but the presser foot does not. Singer sewing macine.
There may be a disconnection between the lever and the presser foot bar. Perhaps a screw has fallen out, broken, or is loose? May need to take it for service.
Sep 25, 2017 | Singer Sewing Machines
Needle bar does not move in zig zag mode on singer 457 stylist and will not move to full left with the position lever
Have you changed your presser foot over to the zig zag foot? On some machines it won't work correctly until you change to the correct presser foot.
Aug 24, 2017 | Singer Sewing Machines
Is there a Walking Foot for the Singer 20U43?
This is what shows on eBay for Singer 20U foot.
http://www.ebay.com/sch/i.html?_from=R40'R40&_sacat=0&_nkw=Singer+20U+foot&_sop=15
I don't find these for 20U43 so one size MAY fit all.
Feb 05, 2015 | Singer Sewing Machines
My Singer XL 6000 upper thread is too tight and keeps breaking, when the presser foot is up the upper thread is loose, but when the presser foot is lowered the threah gets too tight, what I notice is that...
You need to loosen the tension on the machine. There is a dial that has numbers on it. The higher the dial is set, the tighter the tension is. Turn the dial to the left one number. Then try it. Do it over and over. Do not turn the dial all the way down or you will mess up your machine. Do it slowly, one number at a time and try the machine between dials.
Dec 22, 2014 | Singer Sewing Machines
Singer 756 diagram
WD40 on the presser bar at the top and physically move the bar up and down until it frees off, very common
Oct 03, 2013 | Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
My singer HD 110 will sew a bit then suddenly the needle will slow down to a stop & the handwheel seems stuck, yet the motor is still running.
Hello there! Make sure your pattern selector is compatible with the presser foot. Good idea to test with a straight stitch setting: Tension: 4. Width:4-5. Length 5 after you insert a new needle and re-thread machine. Your previous needle may have become bent when machine malfunctioned. Use fabric compatible with needle size. Always raise presser foot when threading! Then always lower presser foot before sewing. Remember to use blue tip scarf needles with synthetic fabric silk thread 50. Purster thread 50, mercerized cotton thread 50-60; #11 or #9 for fine or lightweight fabric with silk thread 50 or fine Pollyester thread; #18 leather needle for leather, #14 - 16 denim . Jimmy Sweep out shuttle carefully with small brush for broken threads and lint.
Mar 31, 2012 | Singer Sewing Machines
I just received a singer 4205 (inspiration) and the presser foot does not move back and forth to pull the material through the machine. It seems to be stuck. I am not a seamstress, but 3 other people...
It is not your presser foot, you must mean the feed dogs, they are what moves the fabric along. Clean and Lubricate your machine. Remove the bobbin case and clean it out. Replace your needle now Totally rethread the machine, according to your manual. Test the threading by putting the presser foot up, pull on top thread, it should pull smoothly, now put your presser foot down, the thread should barely move. This will seat the thread in the tension discs. By the way, try your tension on 3. Also, make sure that your presser foot is down before sewing. Always move the handwheel towards you, never away from you because you will mess up the timing. You will see your feed dogs move if you watch. Download a free copy of you manual at www.singerco.com and save it, plus enlarge the diagrams. If, that does not do the trick call Singer at 1-800-4singer.
Dec 25, 2010 | Singer Inspiration 4205 Mechanical Sewing...
I have a 7466 Singer sewing machine. No matter how I adjust the thread tension, the top thread always pulls the bobbin thread through to the top. I am doing thread painting. The feed dogs are lowered and...
Make sure to thread the machine with the presser foot up to insure the thread is seated into the tension control.
Always free-motion with the presser foot down.
Try a lower setting on the tension.
Mar 28, 2010 | Singer 7466 Mechanical Sewing Machine
Presser foot lever does not lift presser foot
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
Jan 07, 2009 | Sewing Machines
Singer 20u Sewing Machine Logo
394 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
