Question about Health & Beauty
Where can i locate a battery wiring diagram for a rascal autogo 550
Model # 550 rascal autogo looking for a wiring diagram for the batteries of for the charging system
gewiz
  • 1271 Answers
SOURCE: fischer and paykel scooter model sc231ala not charging
hi, if you got a meter , check the voltage o nthe charger socket , it should be about 24v,
that is the left and right pin, not the middle pin that is slighly lower,
if the voltages are going up and down goto the batteries first and chec k the connections on the terminal, tight ?, check them back the the charging socket, normally the charging socket is wires indirectly to the batteries.
Regards
GeWiz.
Posted on Jan 15, 2010
mcdevito75
  • 1970 Answers
SOURCE: batteries do not charge but charger is working.
mcdevito75 here, You may need new batteries, if they are 2 years old or more.
Posted on Jul 02, 2010
  • 692 Answers
SOURCE: I have a Rascal 305.
moleman If the batteries are fully depleted then the on-board charger will not pick them up and charge them to full strength. It is not designed to charge very low batteries. If the batteries stayed fully depleted for a period of time you will have to replace both of them. You should never fully discharge your batteries. The battery level gauge on your chair should be used to determine when to charge if it is the red recharge overnite. Get into the habit of recharging overnite if you use the chair daily. Always store the chair fully charged and if not used weekly charge once a week. Never leave the charged plugged in more than 18 hours. The chair only operates on about a 5-6 volt range from about 21-26 volts. If you are in the red the voltage is down to about 20-21 volts. Hope this helps you
Posted on Sep 29, 2010
  • 2418 Answers
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
Posted on Apr 12, 2011
bugoy31
  • 1238 Answers
SOURCE: How do I get a
Good day!
this is the manual:
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Legend%20Owner%27s%20Manual.pdf
thanks for using fixya..have a nice day!!!
Posted on Jul 02, 2011
Hi i need a wireing diagram for a rascal autogo 555
You can download the service manual from their website.
Dec 06, 2016 | Health & Beauty
Where can I get a wiring diagram?
I may have one around here. need to look.
Any part in particular? was thing about adding an Auto Go section to the app.
Scooter Doctor App
my email is on there ask more stuff
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Sep 05, 2015 | Rascal Auto Go 550 Portable Power Scooter...
Need to replace key switch for my Auto go 550 Ultra lite scooter
Autogo Vision (Autogo 550) - YouTube
? 2:06
www.youtube.com/watch?v=ljs0x1BMaCk
Aug 12, 2014 - Uploaded by Marc's Mobility
Autogo Vision (Autogo 550) ... model shows a quick release mechanism to remove the drive train but it's not made any more so i'm informed.
Aug 05, 2015 | Health & Beauty
Rascal 230 wiring diagram
Check the multi pin connector on tiller and where it connects under the seat between the batteries. Most common problem.
Oct 09, 2014 | Electric Mobility Rascal Scooter...
How do i change my wiring for my autogo 550 to adapt it to a trickle charger. it now has 4 wires , I need 2 wires?
this scooter uses lead acid batteries
this type of battery much like a car type
uses constant voltage
like 13,8v from a car alternator
so a trickle charger is no use and wont work
as it only provides a constant current and not a constant voltage type senario for the charge up
use a car battery charger
problem solved for about a fiver....
the scooter will need eather 12v or 24volts
so you need either a car charger or a truck battery charger
at least 15 amp @ 13.8volts...
Sep 14, 2014 | Radio Communications
Rascal Autogo Vision
try the manufacturer's website .
Dec 07, 2017 | Drive Medical Health & Beauty
Autogo 550
If you are not getting any lights/horn, check all connections and ensure they are properly connected including the batteries.
May 17, 2014 | Health & Beauty
Connecting battaries for a Rascal Autogo
When you put the second battery in the case paying attention to polarity position, the longer wire will go to the top connector. If you have a voltmeter you can identify which wire has 12 volts on it. It should be the brown wire but verify anyway. This wire has to be connected to the NEGATIVE terminal of the second battery in order to get 24 volts to the scooter. The remaining wire connects to the positive terminal of the battery.
May 04, 2017 | Cars & Trucks
Health & Beauty Logo
336 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
